0 members (),
223
37
Topics49,911
Posts838,152
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
And if/when you find the jack, ask yourself what you are going to do with it -- you can't just use it to jack-up one corner. I have a scissor jack = only to be used for a roadside puncture repair. I would use it on the side rails, at a point where there is a crossmember and lifted just enough to get the old wheel off and the new one on.
Posts: 61 Likes: 7
Posts: 61 Likes: 7 |
And if/when you find the jack, ask yourself what you are going to do with it -- you can't just use it to jack-up one corner. I have a scissor jack = only to be used for a roadside puncture repair. I would use it on the side rails, at a point where there is a crossmember and lifted just enough to get the old wheel off and the new one on. That’s the only reason I would need it👍
4/4 70th Anniversary
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
That is a good looking car. If its the one I think it is, it has some nice engine upgrades.
Posts: 61 Likes: 7
That is a good looking car. If its the one I think it is, it has some nice engine upgrades. It does indeed - I can see you are in Nottinghamshire and looking at the paperwork with the car that’s where it spent some of its earlier years It certainly goes well but of course I don’t have a baseline with which to compare it
Posts: 61 Likes: 7
Can I put a tool role in the space under the spare wheel? Unless the tools are hidden cleverly somewhere - and trust me I’ve looked - it seems there are none. Not even a jack! If/when you find the standard tool tray under the carpet/board, check that (due to the poor design, or any maladjustment of your rear suspension) the underside isn't crashing onto the diff housing. And if/when you find the jack, ask yourself what you are going to do with it -- you can't just use it to jack-up one corner. ![[Linked Image]](https://www.tm-img.com/images/2022/03/15/Tool-tray-underside.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/03/15/Diff-housing-rub.jpg) Well it’s no surprise to anyone else but that’s where I found the tools - jack and wheel brace. And yes, I can see where it’s been in contact with the top of the diff. Not as bad as the photos you share though. Now need to work out what to do about it
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
Some years ago I bougt a nice alumium tool tray in the GB. On TM was a thread about the man who build it. I am sure in just a few seconds someone here will show the link to this thread  Edit: I don´t know wether the company still makes tool trays but I found the thread myself Thread about Aluminium Tooltray
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Glad you found the tools!
Insofar as specs for this car were limited to years/colours/interiors and the distinctive leather beading you have this may be the car I saw for sale at Williams a little while back. Yes, fully loaded (no wire wheels), and a bit of a head turner.
Regarding the diff bashing the tool tray, if you do a forum search for "bump stops" posted by Rog this may help. I have them and, like others, am very happy with them, if you cannot find them send me a personal message and I will help.
Toolbox....the post by TBM looks useful.
You will find this forum friendly and informative so go and enjoy your car.
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Well it’s no surprise to anyone else but that’s where I found the tools - jack and wheel brace. And yes, I can see where it’s been in contact with the top of the diff. Not as bad as the photos you share though. Now need to work out what to do about it Some of us have had custom aluminium (preferable) or wood tooltrays built. These make better use of the suspension travel limited space above axle although due to build tolerances need to be sized for each car/model. ![[Linked Image]](https://i.imgur.com/lrVuzUD.jpg) Thread here if interested.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Welcome here, too! And looking around here, you find many things to do, so some more tooltrays: http://www.talkmorgan.com/ubbthreads.php/topics/724046/1Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
