4 members (WJH, Vansrv6, MartinB60, Camelot), 292 guests, and 37 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Black Rat
Black Rat
They are a tight fit I have to thump mine but usually the red mist helps notworthy
Keith
2013 narrow bodied + 4 Ruby.
Don't forget a relay to protect the horn push from the current the horns will draw
2025 MG ZS EV aka Trigger
As my plus4 already had wiring for a second horn, I presumed it was ok to add a second one without adding a relay. It’s been ok for the past 9 years. I found an identical unit with a higher tone at Holdens. It happened to be their cheapest offering at something like £9 at the time. Trust Morgan to select only the finest available!!
I also fitted a vintage style “ooh-ahh” with separate button under the dash, but did fit a diode relay for that one.
Incidentally, I use my horn fairly often when approaching blind bends on our narrow country roads to both warn oncoming traffic and possible horses or walkers. I was always taught to also sound your horn back when hearing one from others to warn them similarly of your oncoming presence. Sadly, drivers rarely seem to do that nowadays.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Black Rat
Black Rat
I've been driving for 60 years and never heard anyone sounding their horn to warn that they were there, but I do live in Essex !
Keith
That explains a lot!
When I was a trainee many moons ago, I had to be assessed by the transport foreman to drive company vehicles. This was one of the things I was tipped off about before going out on the road with him. “If you don’t honk your horn on tight bends, he will fail you” Guess it’s stuck with me and tbh ,, I think it makes a lot of sense....as long as we don’t turn out to be like the streets of India.
Doug
1958 Triton 650
I did not know about the rule to honk before turning but in the old days, as far as I know, one could use your right arm/hand when turning.
I am not sure if it´s allowed nowadays but in a similar manner I wonder if an electric horn can be substituted by the driver screaming loudly and if there is a Satnav beside you ask her to scream as well.
If this would be accepted by the authorities I would have had no problem with my horn push :-)
// Hakanplus8 from Sweden
I honk on sharp blind bends. Brought up in Devon where the lanes don't give any chance of mercy. Similar ones exist in Suffolk
Originally Posted by Hakanplus8
Thanks to all for excellent comments :-).
First I agree that I can not trust the resistance measurement to much and after practicing the horn push a number of times it look better. After all if one use the horn very seldom it is not surprising that things does not work properly all the time.
I will improve the earthing of the push house to the steering column and I will also consider to exchange the two horns from 2001 with new ones and look for some with lower power level as the normal 60 -70 Watts
Once again thanks to everyone. Talk Morgan is really wonderful!
BR. //. Hakan
It's very easy to split the plastic casing of the horns apart,(4 screws) they often trap water in them leading to rust pimples forming on the diaphram, easy to clean up and gives the lazy sounding horn a new lease of life
That's had some serious water ingress. Sort that and it'll be fine.
And in Dorset, especially on Cranborne Chase. Three years ago we took a couple of American friends for a brief tour of the Dorset byways in our tin-top. Apparently one of the ladies kept her eyes closed the whole way. Not my driving, but she'd never been out of the U.S. before and couldn't handle being on the "wrong" side of the narrow roads. Yes I did use the horn.
