7 members (Image, Alan Patterson, Dek, MJF, stefan s, Nick55, Cat302),
257
101
Topics49,871
Posts837,679
Posts: 98 Likes: 2
Posts: 98 Likes: 2 |
The base of the sump has become porous leading to Oil loss. I’ve made some enquires using the part number, but they are obsolete. Tried Rimmers in Lincoln, but no joy. Can anyone help with sourcing a new one? Or maybe the base can be cut out and new plate welded in…… is this an option? I assume they are a steel alloy, but only guessing.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Which Plus 4 engine and what year Gary?
Posts: 98 Likes: 2
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
Looks as though you will have to employ that Chinese chap -- Mr Wel Ding. Actually brazing would be more appropriate. I've just had to repair a porous Rover V8 sump by cutting out the bad section and brazing in a plate.
Posts: 1,415 |
The base of the sump has become porous leading to Oil loss. I’ve made some enquires using the part number, but they are obsolete. Tried Rimmers in Lincoln, but no joy. Can anyone help with sourcing a new one? Or maybe the base can be cut out and new plate welded in…… is this an option? I assume they are a steel alloy, but only guessing. Just send it to me and I’ll repair it…
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 98 Likes: 2
Hi Simon. Apologies for the delay responding. Many thanks for your reply and the offer to repair. There is now some doubt as to whether the sump is actually the cause of the problem. Under further investigation. I'll be back to you when I have more info.
