4 members (IcePack, David_E, PaulJ, DaveW), 316 guests, and 88 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
Page 63 of 91 1 2 61 62 63 64 65 90 91
anyone had a new radiator? is it steel or aluminium?
2015 Roadster Indigo blue
2020 Plus Six Sapphire blue
My Six had a "swirl pot" added while the brakes were done, apparently as a precaution.
Not sure what cars are getting a new rad.
Don’t know but never heard of a steel rad on a car before. Weight, corrosion, poorer thermal conductivity and even if stainless, would be expensive to manufacture.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
If I understood correctly Dan at KH intimated that CX cars that hadn't had any rad issues would have them left in. Not sure if they qualified for swirl pot though which MMC seem to be backing as the "final fix".
Mine hasn’t had any radiator problems but MMC have told me it’s getting a swirl pot fitted. Having said that it’s been there 7 days now and the tracker tells me it hasn’t been moved 1cm since they took delivery. I have had 4 Morgan’s now in the past 6 years. Three of them new. I’m starting to wonder why I bothered.
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
JJR Offline
I took delivery of my Plus Four auto on September 1st 2021 and have not had any radiator problems so far. I am told that when it goes in for the brake recall it will also have a swirl pot fitted. Apparently this is the case for all cars.
John R Marchant
Plus Four JT10MOG "Florence"
Snap. I too took delivery of a Plus Four auto on 1st Sep 2021 and have had no brake or rad problems. Now had the recall done, so fingers crossed.
JJR Offline
Hi Derek,
Happy to hear you have had your brakes done. Have you noticed any difference?
Best regards,
John R Marchant
Hi Derek,
Best regards,
I 'think' they are slightly better but far from wonderful. I drove a Ferrari Roma today and nearly went through the windscreen when I applied the Plus Four amount of brake pressure, But given that I hardly drive fast, the Morgan brakes are adequate,
AKD Offline
Not sure if anyone else has been advised - my dealer says that there is also some clutch work to be done on Plus Four manual version. First I had heard about this. Replacement of “clutch supply line” - a rough translation from German.
Aside from that they confirm new brake master cylinder, changes to some brake lines (I guess due to new MC configuration), swirl pot and attendant coolant pipe modifications are all part of the fix package.
Clutch was a new one to me.
2018 Roadster
2020 M3W
2021 Plus Six
2013 Roadster (prev)
2002 4/4 (prev)
Aston DB11 Volante
