7 members (TeddyAds, RobCol, Strathaven, Graham, G4FUJ, teknome, Hamwich, Dougie),
278
93
Topics49,877
Posts837,735
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
My knob is loose ! It revolves when before it was a nice firm knob. I'm talking about my gear knob of course - what else! I have removed it and screwed it back on but it still rotates. I find this distracting whilst driving but I can't see how to fix it. Is there a solution or do I need a new knob? This looks like the one on my Roadster - https://www.librands.co.uk/products-view-253.html
David 2020 Roadster 3.7 Dove Grey.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
My guess - if the knob is attached the way it is on my car: You just have to unscrew the lower ring- it has an internal thread- then you should see some grub screws. Just tighten them!
My guess - if the knob is attached the way it is on my car: You just have to unscrew the lower ring- it has an internal thread- then you should see some grub screws. Just tighten them! Thanks. I'll take a look and see if this works.
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
Or some PTFE tape on the thread?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
My guess - if the knob is attached the way it is on my car: You just have to unscrew the lower ring- it has an internal thread- then you should see some grub screws. Just tighten them! Also had that problem, try drilling little indents for the grub screws and fix them with Thread Lock.
Posts: 2,093 Likes: 75
Posts: 2,093 Likes: 75 |
The knob and lower ring are both screwed onto a threaded cylinder which is held onto the gearstick with three tiny allen grub screws, which often work loose. It is sometimes be difficult to unscrew the lower ring, so wrap it in a bit of rubber strip and grip with a mole wrench or gas pliers to get it going, whilst holding onto the knob. An identical gear knob can be obtained direct from “Richbrook”, usually much cheaper than other suppliers.
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
As well as some nice designs that are much better. Recommend Richbrook.
Posts: 27,822 Likes: 749
Posts: 27,822 Likes: 749 |
It is fixed by grub screws as described
