6 members (Graham, G4FUJ, John Winn, MartinB60, John V6, nick w, Morganmike), 241 guests, and 57 robots.
+8Rich 69
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,716
#752808 20/08/22 08:38 PM
My knob is loose ! It revolves when before it was a nice firm knob.
I'm talking about my gear knob of course - what else! I have removed it and screwed it back on but it still rotates. I find this distracting whilst driving but I can't see how to fix it.
Is there a solution or do I need a new knob? This looks like the one on my Roadster -
https://www.librands.co.uk/products-view-253.html
David
2020 Roadster 3.7 Dove Grey.
My guess - if the knob is attached the way it is on my car:
You just have to unscrew the lower ring- it has an internal thread- then you should see some grub screws. Just tighten them!
Thanks. I'll take a look and see if this works.
David
Or some PTFE tape on the thread?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Black Rat
Black Rat
Also had that problem, try drilling little indents for the grub screws and fix them with Thread Lock.
Keith
2013 narrow bodied + 4 Ruby.
The knob and lower ring are both screwed onto a threaded cylinder which is held onto the gearstick with three tiny allen grub screws, which often work loose. It is sometimes be difficult to unscrew the lower ring, so wrap it in a bit of rubber strip and grip with a mole wrench or gas pliers to get it going, whilst holding onto the knob.
An identical gear knob can be obtained direct from “Richbrook”, usually much cheaper than other suppliers.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #752918 21/08/22 07:17 PM
As well as some nice designs that are much better. Recommend Richbrook.
Costock, UK
Disco 5
It is fixed by grub screws as described
