0 members (),
288
Posts837,277
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I've noticed that some people have fitted elasticated cargo nets to the sides of the footwells. What nets have you used and how have they been fixed?
Andy
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Hi Andy, Here's a thread from 2017 on my install. I riveted them to the side panels of the Coco Mats I bought, and then Velcro'd the assembly to the side panel. Still working well. Cargo net install on the 2nd page of this post: Thread: http://www.talkmorgan.com/ubbthreads.php/topics/477781/2I bought them from Amazon, can look up specifically which ones, don't recall at the moment. The aluminum backing strips are helpful to stiffen-up the pocket against the mat. I subsequently removed the passenger footwell box - it's useless - and only keep reg and insturance papers in the driver's side, use the passenger for cables, etc. Works well.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I used a "footwell cargo net" (450mm x 220mm) with wire frame on 3 sides, off eBay for about £20 for a pair now. Cable ties to the chassis tube at the rear end and some 36mm spring clips on threaded bar at the front, clipped onto the chassis rails with foam padding cable tied to stop the contents sliding out of the front on braking. I only have it fitted on the passenger side. It all seems to work and has been fitted for several years, very useful storage. ![[Linked Image]](https://www.tm-img.com/images/2022/08/25/IMG_2266.md.jpg)
Thanks for the help on this. I decided to make up a wooden frame from some 16mm ply that I had lying around. ![[Linked Image]](https://www.tm-img.com/images/2022/09/04/Bunny_Net_1.jpg) I routered around the rear edge so that it's a snug fit between the chassis tubes. ![[Linked Image]](https://www.tm-img.com/images/2022/09/04/Bunny_Net_2.jpg) I used a Silverline 300x300 cargo net with the metal hooks removed. It's all held in place with tie-wraps and the resulting storage area is surprisingly generous at around 24cm high by 45cm long and 5cm deep. Access is via the top edge where the net isn't attached to the frame. ![[Linked Image]](https://www.tm-img.com/images/2022/09/04/Bunny_Net_3.jpg) Great for waterproofs, fire stick, etc, etc I reckon.
Andy
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
Andy, this is a really useful tip. Thanks for posting. I may have to try this as well. I currently have my Element 50 fire extinguisher mounted down there, but having the plywood would give me another place to mount that as well.
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
How easy is it to access the Firestick in a "desperate" situation? Great idea for waterproofs storage, etc.
