Topics49,838
Posts837,295
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Trying to get my wheels off and they're not playing. Haven't been off for a while so they're stuck on tightly. This spanner is prone to slipping off the nut, and simply won't budge it at the moment. Anybody use a better design? Thanks in advance. https://www.tm-img.com/image/zSCtqhttps://www.tm-img.com/image/zSBdR
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Try using a blowlamp to gently apply a bit of heat just to the centre nut. Also try the standard spanner and a dead blow hammer if you have one. With the wheels on the ground.
Success. Thanks Dave. I used boiling water from a kettle to heat the nut, and the standard, unopened and still in its wrapping, spanner and mallet to slowly get it off. Took quite a lot of bashing which was very close to the rims so I taped those up with electrical tape just in case. Mrs FT operated the front brakes. Think I'll give the threads a good clean and a re-grease before reassembling. I've not been greasing the kingpins as enthusiastically as I used to after suffering grease on the discs so haven't been taking the wheels off regularly. Might just have to start cleaning the inside of the rims more often so I get to take the wheels off. https://www.tm-img.com/image/zVKr7https://www.tm-img.com/image/zV8Yu
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
I would be very surprised if a dead blow hammer wont get them going. One hand over the nut, holding the spanner in place and a few sharp taps with the hammer. Easy to forget that the off side is a left hand thread but sure you are well aware of that.
I would be very surprised if a dead blow hammer wont get them going. One hand over the nut, holding the spanner in place and a few sharp taps with the hammer. Easy to forget that the off side is a left hand thread but sure you are well aware of that. Got it sorted thanks (see above) but it wasn't a few sharp taps - more like a flurry of blows for a sustained period of time! (after heating first). Used to come of easily with my long-handled spanner.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
I used exhaust U bolts to bolt that Mulfab tool to a roof rack . Works a treat if all else fails. The photo is the mark 1 version with jubilee clips. ![[Linked Image]](https://www.tm-img.com/images/2021/04/21/20210421_171538.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/04/21/20210421_171544.jpg)
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
I bought one of these from Millers, I don't know if they are still in business though, it was perfect for my Sport but my Plus 8 has larger sized centre lock nuts. ![[Linked Image]](https://tm-img.com/images/2017/11/17/P26-01-15_13.19.jpg)
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
One of these from Lionel you need - it was approx £50 from memory He also makes them for the Hexagonal wheel nuts ![[Linked Image]](https://tm-img.com/images/2021/04/15/400915A6-1007-4A7C-AAF4-2D12F81E2687.jpg) ![[Linked Image]](https://tm-img.com/images/2021/04/15/9B465F4E-750F-4C85-85EF-19911EB503D7.jpg) ![[Linked Image]](https://tm-img.com/images/2021/04/15/6A6A833F-6925-411A-875A-6E770031D7CE.jpg)
Craig Jezz
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
A hot air gun - paint stripper thingy, is good for heating seized spinners, less risky than a open flame blowtorch
Brian Miller and Lionel have both retired
