1 members (Morganmike), 149 guests, and 59 robots.
+8Rich 94
Posts837,276
Trying to get my wheels off and they're not playing. Haven't been off for a while so they're stuck on tightly. This spanner is prone to slipping off the nut, and simply won't budge it at the moment. Anybody use a better design? Thanks in advance.
https://www.tm-img.com/image/zSCtq
https://www.tm-img.com/image/zSBdR
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Try using a blowlamp to gently apply a bit of heat just to the centre nut. Also try the standard spanner and a dead blow hammer if you have one. With the wheels on the ground.
Success. Thanks Dave. I used boiling water from a kettle to heat the nut, and the standard, unopened and still in its wrapping, spanner and mallet to slowly get it off. Took quite a lot of bashing which was very close to the rims so I taped those up with electrical tape just in case. Mrs FT operated the front brakes. Think I'll give the threads a good clean and a re-grease before reassembling. I've not been greasing the kingpins as enthusiastically as I used to after suffering grease on the discs so haven't been taking the wheels off regularly. Might just have to start cleaning the inside of the rims more often so I get to take the wheels off.
https://www.tm-img.com/image/zVKr7
https://www.tm-img.com/image/zV8Yu
Morgan Plus 4
Brompton M6L
Giant TCX Advanced
I would be very surprised if a dead blow hammer wont get them going. One hand over the nut, holding the spanner in place and a few sharp taps with the hammer. Easy to forget that the off side is a left hand thread but sure you are well aware of that.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Got it sorted thanks (see above) but it wasn't a few sharp taps - more like a flurry of blows for a sustained period of time! (after heating first). Used to come of easily with my long-handled spanner.
Morgan Plus 4
Brompton M6L
Giant TCX Advanced
I used exhaust U bolts to bolt that Mulfab tool to a roof rack . Works a treat if all else fails. The photo is the mark 1 version with jubilee clips.
I bought one of these from Millers, I don't know if they are still in business though, it was perfect for my Sport but my Plus 8 has larger sized centre lock nuts.
One of these from Lionel you need - it was approx £50 from memory
He also makes them for the Hexagonal wheel nuts
Craig Jezz
A hot air gun - paint stripper thingy, is good for heating seized spinners, less risky than a open flame blowtorch
Brian Miller and Lionel have both retired
