9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff),
298
82
Topics49,858
Posts837,463
Posts: 3,643 |
Ivanford, will do. THANK YOU.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I had the same access problem, solved by an angled nipple, available straight, 45 degrees or 90 degrees from your local motor factor
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 3,643 |
Hi Taffmog, I'll find a motor factor and buy one of each to get the optimum fit.
Posts: 3,643 |
an update Taffog and Ivanford:-
Taffmog, I have purchased a straight and a 90 degree nipple from a local motor factor. I guess they do not get many requests for these as they were not able to tell me the sizes so I guessed.
Before fitting them I took Ivanford's suggestion and inserted a washer on the original one and I can now connect the grease gun without removing the damper. I'll keep them for future use.
Thanks for you both for your advise.
Posts: 1,502 |
Angled nipples do the job very well, especially if you fit AVO shock absorbers, which do not leave enough room to access the straight nipples.
To get the angled nipples to point in the direction you want, you may need to use a brass washer.
