8 members (verysideways, Robbie, Luddite, James B W, TalkMorgan, John V6, Julian BB, jbk),
219
70
Topics49,883
Posts837,816
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Good evening
As I'm bedridden and a tad bored I thought I'd put together a toolkit/spares kit for the car. I have been looking at previous posts and can see there are essentially two types of relay but no one appears to give a definitive part number for either (certainly not one that can be successfully searched).
Can somebody please shed some light on the two part numbers so I can order some?
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 8,685 Likes: 414
Posts: 8,685 Likes: 414 |
The relays and their pin outs are generic. As spares best to have diode protected 12 volt 40 amp 5 pin relays. Not all applications use the 5th pin which allows changeover contacts but will replace a make/break relay whether it has 4 or 5 pins. Important they have diode protection (quenching) to avoid damage to any associated electronics. They sometimes come with a redundant plastic or metal bulkhead mount which can be removed since they are supported by the socket they plug into. Source below: ![[Linked Image]](https://i.ebayimg.com/images/g/9c4AAOSwezVWxaFX/s-l1600.jpg)
Otherwise any good auto spares outlet in France should stock them. Just show them above pic.
Posts: 27,825 Likes: 753
Posts: 27,825 Likes: 753 |
Halfords sell them . You need to compare the diagram on the relay to the photos on their website. Halfords relaysMSCC members can print a 10% discount voucher. I note you are in France so I guess other websites could help. If you 2011 car is like my 2014 one then the ac relay is not used and can act as a spare. Not the case if you have aircon.
Posts: 185 Likes: 2
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
And if ever wiring one from scratch, it is essential that a diode relay is wired the right way round, otherwise it’s goodbye relay and associated circuit fuse. It might help by remembering that “86 is a bit more positive than 85”, so 86 gets the + connection.
They are integral to the relay now Doug as per schematic on relay housing.
And if ever wiring one from scratch, it is essential that a diode relay is wired the right way round, otherwise it’s goodbye relay and associated circuit fuse. It might help by remembering that “86 is a bit more positive than 85”, so 86 gets the + connection. Yes, realise that Richard. Replacing an existing relay is foolproof. However, I was referring to when a new relay and base are added to drive some additional item.
