6 members (bmgermany, Ian Wegg, John Winn, DCH, RichardV6, Graham, G4FUJ),
321
88
Topics49,847
Posts837,389
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
had this happen on a Gilbern Invader on cold mornings Ditto experience with a Gilbern Invader Mk2 Estate. Can't be many ex-Gilbern drivers on here. Purple Mk2 Estate...................
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Similar experience with a mk 1 Vauxhall Astra. It had a hose from the air filter down onto a collector on the manifold that rusted and was pulled off and chucked. After two or three late night winter breakdowns I got a replacement from the local scrapyard. Problem solved.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Ditto on an MG midget on a cold autumnal day with freezing fog.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Remember when folk used to tie a piece of cardboard over part of the front grille in winter ?
We even had a sort of shallow drum paraffin heater that you lit overnight and shoved under the engine
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.
Anyone remember those black plastic covers on the grille that you could progressively un popper as conditions allowed.
Jon, excellent thanks I can't remember the last time I saw one.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.. In Norway every car has a 230V heater. I tried a long time to find such heater that I coult make fitting to my CX500.
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
When I was about 18 and driving a Sunbeam Rapier which had no garage I used to leave a small parafin lamp thing under the engine in winter. Anyone remember those?
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.. In Norway every car has a 230V heater. I tried a long time to find such heater that I coult make fitting to my CX500. Like this one.
