7 members (Adam12, Tim1598, Clipper, RichardV6, Mybluemog, nick w, MDS61),
413
42
SORN
New
Topics48,372
Posts813,491
Members9,215
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
had this happen on a Gilbern Invader on cold mornings Ditto experience with a Gilbern Invader Mk2 Estate. Can't be many ex-Gilbern drivers on here. Purple Mk2 Estate...................
Posts: 1,212 Likes: 24
Posts: 1,212 Likes: 24 |
Similar experience with a mk 1 Vauxhall Astra. It had a hose from the air filter down onto a collector on the manifold that rusted and was pulled off and chucked. After two or three late night winter breakdowns I got a replacement from the local scrapyard. Problem solved.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
Ditto on an MG midget on a cold autumnal day with freezing fog.
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
Remember when folk used to tie a piece of cardboard over part of the front grille in winter ?
We even had a sort of shallow drum paraffin heater that you lit overnight and shoved under the engine
Posts: 35,800 Likes: 474
Posts: 35,800 Likes: 474 |
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.
Anyone remember those black plastic covers on the grille that you could progressively un popper as conditions allowed.
Jon, excellent thanks I can't remember the last time I saw one.
Posts: 2,064 Likes: 57
Posts: 2,064 Likes: 57 |
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.. In Norway every car has a 230V heater. I tried a long time to find such heater that I coult make fitting to my CX500.
Posts: 3,668 Likes: 43
Posts: 3,668 Likes: 43 |
When I was about 18 and driving a Sunbeam Rapier which had no garage I used to leave a small parafin lamp thing under the engine in winter. Anyone remember those?
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.. In Norway every car has a 230V heater. I tried a long time to find such heater that I coult make fitting to my CX500. Like this one.
