3 members (Morganmike, Cerberas, MJF), 246 guests, and 28 robots.
Topics49,860
Posts837,486
Jonny72
Page 2 of 5 1 2 3 4 5
Originally Posted by JMcL
Originally Posted by DaveW
had this happen on a Gilbern Invader on cold mornings
Ditto experience with a Gilbern Invader Mk2 Estate. Can't be many ex-Gilbern drivers on here.
Purple Mk2 Estate...................
Similar experience with a mk 1 Vauxhall Astra. It had a hose from the air filter down onto a collector on the manifold that rusted and was pulled off and chucked. After two or three late night winter breakdowns I got a replacement from the local scrapyard. Problem solved.
Gordon Duguid
Ditto on an MG midget on a cold autumnal day with freezing fog.
Remember when folk used to tie a piece of cardboard over part of the front grille in winter ?
We even had a sort of shallow drum paraffin heater that you lit overnight and shoved under the engine
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight.
Anyone remember those black plastic covers on the grille that you could progressively un popper as conditions allowed.
Jon, excellent thanks I can't remember the last time I saw one.
Originally Posted by +8Rich
When I worked in Canada there was a plug in the front of the car which had a heater in the sump you plugged into the 110volt supply overnight..
In Norway every car has a 230V heater. I tried a long time to find such heater that I coult make fitting to my CX500.
When I was about 18 and driving a Sunbeam Rapier which had no garage I used to leave a small parafin lamp thing under the engine in winter. Anyone remember those?
Like this one.
