9 members (TalkMorgan, Luddite, gazum, Soleng, Mike D, Farmershands, BobtheTrain, High Hamster, mickyb), 386 guests, and 16 robots.
+8Rich 92
Posts837,284
Page 15 of 164 1 2 13 14 15 16 17 163 164
Thanks it looks pretty trick.
Out of necessity really ... the 5 speed linkage stuck out several inches through a ragged hole in the old tunnel (like the alien bursting out of a spaceman's chest 🙂) ... needed something to cover/accommodate that to get me out driving so made the box ... when we get a bad snow patch over winter I'll.pretty it all up ... til then it's a bit utilitarian.
It was inspired by the similar boxes over the shift in my A40 Farina (first car) and early Midget (first sports car I drove) ... a nod to my motoring roots 🙂
TBM Offline
They made a right pig ears of that - your solution looks much better!
Not sure why they cut it about so much - my five speed fitted within the existing gearbox tunnel, and the lever poked through the same hole at the 4 speed. The only alteration I made was slightly enlarging the hole to make it easier to get to the three gear lever mounting bolts.
Indeed ... hole looked like it was cut with a hatchet .... oddly, on mine the gear-lever wouldn't have gone through the same hole by a couple of inches and its mounting sits well above the old tunnel profile, hence the butchery ... over winter I'll sort some gaiters and tidy/spray the box and all will be well ... does the job. Racers can he a bit brutal when it's not something critical.
How do you find the shorter gear stick? .... I want to shorten my shift as, at present, there's not much room between my hand and the bottom of the dash .... is it a normal gearstick but shortened or a purpose made 'quickshifter' mod?
TBM Offline
It's just a shorter lever - I cut the end off, ground down the stock and cut a new thread. Really smooth - no issues.
Originally I had a quick shift, but the gate was far too tight and found it a real pain to use. I would probably have got used to it, but after a week of missed/wrong gears I went back to original.
Will get my hacksaw out .... thanks for the info 🙂
Fitted a fire extinguisher behind the drivers seat. Easy to fit and out of the way.
Firexo
1956 Plus 4 4 seater
TBM Offline
I've gone for a couple of those firesticks - tucked down the side of the seat.....
TBM Offline
My tonneau cover zip broke while I was in the Lake District late August, so booked in with Allon White to have it replaced (my usual trimmer has relocated unfortunately). First available slot was this week.
Dropped it off after work on Monday at 5.00pm - had a phone call Tuesday 10.30am saying it was done, All for a very reasonable £80. Very pleased. I'm often quick to moan about dealers and prices so credit where credit is due.
The previous zip was 'suit trouser' size - the new one is 'wet suit' size so much better too.
Sounds like a good result, and the reason a few of us on TM recommend Shaun at Allon White's trim dept
