0 members (), 189 guests, and 39 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#75833 06/12/11 10:39 AM
V
V
Having recently purchased a 2009 4/4 Sport, could someone tell me where to find the battery as I wish to fit a charger.
Thanks, Jack
Vancouver #75834 06/12/11 10:40 AM
the Battery is behind the passenger seat, if you remove the carpet you will see an alloy plate, remove this and the battery is in there.
Sorry I meant to say passenger not driver.
ivanford #75836 06/12/11 10:54 AM
Should be behind the passenger seat (LHS)
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
NorthernMogman #75844 06/12/11 12:44 PM
V
V
Thanks both for your prompt advice, i am fitting a permanent connection for a battery conditioner.
Jack
Vancouver #75845 06/12/11 01:11 PM
Posting Desperado
Posting Desperado
behope you are made of rubber and have multi joints on your arms and fingers because its a pig to get at and remove . I slipped and fell into the rear area while leaning over and my wife could not stop laughing wanted to take a photo of me legs up in the air .
Jack The Lad #75849 06/12/11 01:52 PM
It is also worth checking to see whether you can charge via the lighter socket (under the dash). I trickle charge my Plus 4(using a Ctek) via that socket and it is the easiest solution. Check to make sure the 4/4 has the same live socket and if so, that is another option for you.
Simon #75853 06/12/11 02:23 PM
It may be easier by removing the tool tray and working that way.
Remember to fuse the circuit.
John V6 #75858 06/12/11 03:32 PM
We 4/4 Sport owners don't have tool trays......we are stripped for action! That said, it is easy enough to take off the "boot" floor which gives you better access to the battery although I'd do for the lighter socket option....it stays live with the ignition off.
Jays #75859 06/12/11 03:34 PM
The Ctek is a good idea. Find a flat place near the battery and connect it permanently. M.
meabh #75878 06/12/11 05:19 PM
Battery conditioner? What the hell, just drive the thing....
'67 +4 tourer - broken white - RHD
