10 members (JJW, Soleng, jbk, High Hamster, GrumpyPa, BobtheTrain, Trim, DaveK, BrunswickGreen44, NickCW), 285 guests, and 38 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,930
Members9,203
toitoine
I have the roller type pedal installed, nothing is loose and on new roads everything is fine.
Craig, do you have more details on the pedal you ordered from WP? Is this the 'GDi Accelerator Arm & Pedal' (they have different ones in their shop)?
If this also fits LHD cars I may order one.
2009 4/4 Sport
1932 Three Wheeler SS
other stuff.....
Unless you have extremely bumpy roads, this throttle behaviour appears to be totally abnormal. This seems to be backed up by Heinz’ experiences in a similar model. Following his advice, before wasting money on pedal plates etc, I would strongly advise that you look first to see if it is indeed “fly by wire”. This means that there is only an electrical connection between the throttle pedal and the engine compartment, instead of the traditional bowden cable. If so, then I would strongly suspect a faulty or loose throttle position sensor.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I have a 2016 4/4 sport, so I assume it’s the same set up as yours.
All the info is here where I purchased mine.
https://www.wolfperformance.co.uk/product/pedal-kit/
Installation guide
https://www.wolfperformance.co.uk/wp-content/uploads/2021/12/Pedal-Kit-Installation.pdf
Craig Jezz
Hi Doug, it is definitly 'fly by wire', the throttle position sensor is definitly not loose (just checked).
I will check the sensor before I order other parts.
@ Craig: thanks for the links!
2009 4/4 Sport
other stuff.....
I ordered just the pedal piece from them, not the arm. I unscrewed the roller and screwed the pedal on. I like it much better than the roller.
I don't know if it is still available since it isn't on their site. A call may be needed.
1973 4/4 "Henry A"
1953 +4 Flat Rad "Pug"
1984 Citoen 2CV Special "BeBe"
https://morgan34.org/
That would be nice to have. I can't heel-and-toe with the roller, and it's making me nuts.
Pauly...It's still on their site.
I didn't see it, but that's no surprise. Yes, heal/toe works with the pedal!
It's a fairly simple item, and I might have been able to make one myself. But it wasn't very expensive.
1973 4/4 "Henry A"
