12 members (James B W, Luddite, TBM, JohnSpain, nestor59310, RichardV6, planenut, Ian Wegg, uvk33n, Davetherave, DaveW, Morganmike),
260
69
Topics49,914
Posts838,195
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
Might be a bit of a long shot but I’m after x2 Sigma 4/4 cam cover bolts as pictured which are standard fitment on the Sigma engine. Unfortunately my local Ford dealer tells me they are only available if you order the full kit including the cam cover itself which is cost prohibitive. Any help in obtaining them would much appreciated. Thanks. ![[Linked Image]](https://i.postimg.cc/vBSXCbKx/A0-B71-D8-D-1-B78-45-F9-84-E7-6-E1-D5-F7-EE65-D.jpg)
Kevin Davies
Posts: 12,268 Likes: 324
Posts: 12,268 Likes: 324 |
Would it be possible to use a length of stainless metric studding with a Flange nut and a locknut as a substitute?
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
It looks like a stud bolt. Did you mesure the bolt and surch for it?
Or use a bolt that fits and cut off the head?
Posts: 81 Likes: 1
Both of those are possible if I can’t source the correct bolts.
Kevin Davies
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
Those are not bolts simply studs and flanged nuts by the look of it. If you remove the nut then lock together two similar thread nuts you should be able to extract the stud from head. Suitable plain studding cut to size and locktited in could replace. You haven't explained why you need "bolts" in the first place though
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
Richard, I hate to say but they are all one piece. A Ford special. They look the same as those fitted to the Duratec and may be other Ford engines. So I would try a scrap yard. On some engines they have a rubber socket srewed onto the top thread to mount the engine cover on. Cheers John.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Those are not bolts simply studs and flanged nuts by the look of it. If you remove the nut then lock together two similar thread nuts you should be able to extract the stud from head. Suitable plain studding cut to size and locktited in could replace. You haven't explained why you need "bolts" in the first place though  kev has a Sigma engine cover that he wants to fit, he has this set up on the manifold side, and has the studs with nuts on the inlet side. He wants to install the studs so the new engine cover fits over the top without the need to remove the main cam-cover bolts when you need to access the spark plugs. ![[Linked Image]](https://tm-img.com/images/2022/10/26/502452CE-0006-43E9-B54D-43E4496CBBC8.jpg) So the cover fits like this one ![[Linked Image]](https://tm-img.com/images/2022/10/26/0EC03996-2FD7-46AD-8DE2-0977769ABEA8.jpg)
Craig Jezz
Here is a pic of the Ford stud and cover mount. As I said in my previous post I would try a scrapy. Or you could just use studding ("all thread" as is the modern term that I hate) with a nut glued on. Cheers John ![[Linked Image]](https://tm-img.com/images/2022/10/26/DSC03857.md.jpg)
Posts: 81 Likes: 1
Here is a pic of the Ford stud and cover mount. As I said in my previous post I would try a scrapy. Or you could just use studding ("all thread" as is the modern term that I hate) with a nut glued on. Cheers John ![[Linked Image]](https://tm-img.com/images/2022/10/26/DSC03857.md.jpg) Thanks John, are you able to measure the length please?
Kevin Davies
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
I've not checked their website for the later engines. but Burton Power are good for Ford oily bits
