9 members (IcePack, TBM, Image, MATTMOG, chanteclair, Tom Sayles, CJB, +8Rich, Moggo),
259
78
Topics49,868
Posts837,631
Posts: 40 |
without jacking up my 4/4 can anyone tell me if a 2016 car has grease nipples fitted
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
Yes there should be three, front and rear UJ spider and the front sliding joint.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Hi Barry13
I have 2016 Morgan 4/4 and yes It does have a grease nipple on the prop shaft. From memory it’s not easy to access on my car, which is why i get Williams Automobiles to grease it during the annual service.
Craig Jezz
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Yep 3. You may be lucky and have an access hole in the gearbox tunnel. Otherwise you need to get in underneath for the front , which really requires a lift. I put a post on the pre cx trad area on my 3.7l Roadster and accessing the front ujs. For the rear you can remove the tool tray and access the nipple.
Just give them a half pump of grease once a year
Posts: 40 |
Ok thanks to you all for the info will have a look for the access hole to see if ime lucky if not looks like ramps
