10 members (+8Rich, High Hamster, MartO, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH, sezznowt), 311 guests, and 106 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
#760044 01/11/22 06:37 PM
Barry13 Offline OP
without jacking up my 4/4 can anyone tell me if a 2016 car has grease nipples fitted
Barry13 #760047 01/11/22 06:49 PM
Online NoMood
Yes there should be three, front and rear UJ spider and the front sliding joint.
Barry13 #760048 01/11/22 06:51 PM
Hi Barry13
I have 2016 Morgan 4/4 and yes It does have a grease nipple on the prop shaft. From memory it’s not easy to access on my car, which is why i get Williams Automobiles to grease it during the annual service.
Craig Jezz
Barry13 #760063 01/11/22 10:34 PM
Black Rat
Black Rat
Yes 3
Keith
2013 narrow bodied + 4 Ruby.
Barry13 #760066 01/11/22 11:14 PM
Yep 3. You may be lucky and have an access hole in the gearbox tunnel. Otherwise you need to get in underneath for the front , which really requires a lift. I put a post on the pre cx trad area on my 3.7l Roadster and accessing the front ujs.
For the rear you can remove the tool tray and access the nipple.
Just give them a half pump of grease once a year
Barry13 #760136 02/11/22 05:11 PM
Barry13 Offline OP
Ok thanks to you all for the info will have a look for the access hole to see if ime lucky if not looks like ramps
Barry13 #760138 02/11/22 05:25 PM
