7 members (Image, MavisTheMorgan, Gramrugby, sewin, Grumpy2, sbarracl, Biggle), 198 guests, and 31 robots.
+8Rich 92
Topics49,838
Posts837,294
Page 3 of 6 1 2 3 4 5 6
Just be aware Dave the self adhesive strips stick firmly on first contact so recommend a dry run with protective red film in place to ensure seal sits correctly over full length. Note also as supplied the bottom end needs prior trimming to a point with Stanley knife. This is much easier if you are replacing like for like and have a pattern.
Thanks Richard, good tips and much appreciated.
I'll dry fit and proceed with caution thumbs
Does anyone know if these new seals will fit a 2006 4/4 with folding windscreen?
4/4 70th Anniversary
It's wondering about this myself!
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
I had them on my 06 Roadster. Maybe you can post a picture of the A pillar to be safe
Rog Offline OP
Can’t help other than perhaps this.
Roger
Thanks John/Rog
The car isn’t stored/garaged at home but will get a photo over the weekend
Rog,
Thanks for the info. The A pillar is a "Z" section length of metal sandwiched between screen frame and folding mechanism.
A quick measurement.....15mm for any seal!
So thanks for diagram which was very useful
Regards
Geof
Originally Posted by Montegue
Let's hope the supplier is more effective with my seal order than they were getting a pair of spot light mounts to me, despite confirming at the start of the process the brackets were in stock, over three weeks and four telephone calls later I was forced to ask for a refund and buy an alternative set from Librands frown
The seals arrived today, good job Williams thumbs
Originally Posted by SALMO
Rog,
So do you think these will be ok for the 70th Anniversay car?
