1 members (JoeSpeetjens),
347
41
Posts837,276
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Just be aware Dave the self adhesive strips stick firmly on first contact so recommend a dry run with protective red film in place to ensure seal sits correctly over full length. Note also as supplied the bottom end needs prior trimming to a point with Stanley knife. This is much easier if you are replacing like for like and have a pattern.
Posts: 1,042 Likes: 148
Posts: 1,042 Likes: 148 |
Thanks Richard, good tips and much appreciated. I'll dry fit and proceed with caution
Posts: 61 Likes: 7
Posts: 61 Likes: 7 |
Does anyone know if these new seals will fit a 2006 4/4 with folding windscreen?
4/4 70th Anniversary
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Does anyone know if these new seals will fit a 2006 4/4 with folding windscreen? It's wondering about this myself!
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
I had them on my 06 Roadster. Maybe you can post a picture of the A pillar to be safe
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Does anyone know if these new seals will fit a 2006 4/4 with folding windscreen? Can’t help other than perhaps this. ![[Linked Image]](https://dl.dropboxusercontent.com/s/wbikatr4n5bccs8/seal%20sec.jpg)
Roger 2011 Plus 4
Posts: 61 Likes: 7
Thanks John/Rog
The car isn’t stored/garaged at home but will get a photo over the weekend
Posts: 383 Likes: 6
Rog,
Thanks for the info. The A pillar is a "Z" section length of metal sandwiched between screen frame and folding mechanism. A quick measurement.....15mm for any seal!
So thanks for diagram which was very useful
Regards
Let's hope the supplier is more effective with my seal order than they were getting a pair of spot light mounts to me, despite confirming at the start of the process the brackets were in stock, over three weeks and four telephone calls later I was forced to ask for a refund and buy an alternative set from Librands  The seals arrived today, good job Williams
Posts: 61 Likes: 7
Rog,
So thanks for diagram which was very useful So do you think these will be ok for the 70th Anniversay car?
