4 members (gaston, Zach, piquet, Chris Cosher), 342 guests, and 46 robots.
+8Rich 92
Topics49,838
Posts837,294
Page 2 of 6 1 2 3 4 5 6
Originally Posted by Rog
I wish you had told me sooner Bernt smile
Doug, we need a picture..
I did Rog, I did!
a pillar seal
You are a real gentleman that doesn't read any praise for you innocent
Rog Offline OP
Sorry Bernt, I missed the thread. frown
One hundred lines. “I must pay better attention….”
I will consider myself reprimanded getcoat
Roger
I did Rog, I did!
a pillar seal
Correction made to link above.
Not sure what Doug is referring to but this is picture of mine which look very similar to your new ones Rog.
It's the outer lip that has split at the bottom.
Richard, I noticed when new my seals were applying a lot of twist to the lip as the sidescreen frame closed & opened over it, I put a steel ruler against it and carefully trimmed a tiny sliver off with a scalpel, which solved mine, plus I lube them occasionally with a bit of clear Autoglym tyre dressing on the 'fin'
Thanks Doug and well done with the pic thumbs
Job done but I only had some EPDM sheet.
A very neat job!
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Thanks Jon, will try that with the new ones although I do lube them occasionally.
Rog Offline OP
A very neat job!
Thanks! I hadn’t really thought about sealing here before. I don’t know how effective the harder material will be compared to the squishy foam but the roof appears to sit on it nicely, so far....
Roger
Pulling the old seals off leaves a strip of the self adhesive material firmly stuck to each inner edge of windscreen pillar. This is extremely difficult to remove until I discovered this method:
Soften remaining material with brake cleaner then start peeling from edge with finger nail. Once started continue with downward thumb pressure. The material should peel off cleanly rolling into a ball which can be picked off when large enough. Clean any residue with paper towel soaked in brake cleaner. This leaves clean surface ready to accept new seals.
Rog Offline OP
And a pic of the front rail sat on the rubber pad with the roof locked down.
If nothing else it should help protect the paint...
Roger
Damn you Rog, another thing I now have to buy for Monty swear
Seriously though, thanks for sharing, these seals look like a 'must have' thumbs
Only last week I added a run of self adhesive neoprene up the inner leading edge of both side screens to create a neoprene on neoprene seal, this eliminated the rattles and created a better seal reducing wind noise, but these lip seals look like a way better solution so I've just bpoght a pair.
Let's hope the supplier is more effective with my seal order than they were getting a pair of spot light mounts to me, despite confirming at the start of the process the brackets were in stock, over three weeks and four telephone calls later I was forced to ask for a refund and buy an alternative set from Librands frown
Fingers crossed the seals will be with me for Saturday as I'm prepping Monty for a run to Goodwood on the Sunday.
