7 members (TeddyAds, Gordon D, rossocorsa, MJF, sprinty, cerealsurfer, JohnHarris),
234
65
Topics49,860
Posts837,522
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
Nice work as usual, Craig. I took the normal “Ewanist” approach and just sprayed the whole clump of rusty muck with satin black, works really well for at least a fortnight
Posts: 2,093 Likes: 73
Posts: 2,093 Likes: 73 |
Resurrection of this post. I noticed that my exhaust bobbins on my 2011 plus 4 are just showing signs of perish. questions: 1. Can they be replaced without disconnecting exhaust pipes and silencer /manifold joints? 2. The L-shaped bracket that is bolted to the chassis: Are the bolts captive as the nuts are on the outside but the heads are not readily accessible.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
I replaced the 4 bobbins on my 4/4 without disturbing anything else.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Yes really easy to change, no need to disconnect exhaust pipes etc ![[Linked Image]](https://tm-img.com/images/2021/08/15/9EEC5CAA-1F12-4792-99FD-64D6038060F4.jpg)
Craig Jezz
Thanks for replies from two 4/4 owners, but it only answered my question 1. Not sure if it is the same arrangement as the +4. The issue as I see it is that the bottom fixing of the bobbins is on a L shaped bracket that is bolted to the chassis. The top fixing is on a plate that shares a fixing with the silencer u- clamp.It looks to me that the only way of doing it is to remove the L bracket, but are the bolts that hold it, captive, or are they likely to either slip inside the chassis rail or when re- tightening, go round and round. That’s really all I need to know.
Posts: 1,415 |
Thanks for replies from two 4/4 owners, but it only answered my question 1. Not sure if it is the same arrangement as the +4. The issue as I see it is that the bottom fixing of the bobbins is on a L shaped bracket that is bolted to the chassis. The top fixing is on a plate that shares a fixing with the silencer u- clamp.It looks to me that the only way of doing it is to remove the L bracket, but are the bolts that hold it, captive, or are they likely to either slip inside the chassis rail or when re- tightening, go round and round. That’s really all I need to know. There’s enough float and flex in the exhaust system to just under the bobbin nuts and lift the system off of them
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
The chassis fixings are captive
Many thanks Simon and Dave. Exactly what I hoped to hear.
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
Thanks for replies from two 4/4 owners, but it only answered my question 1. Not sure if it is the same arrangement as the +4. The issue as I see it is that the bottom fixing of the bobbins is on a L shaped bracket that is bolted to the chassis. The top fixing is on a plate that shares a fixing with the silencer u- clamp.It looks to me that the only way of doing it is to remove the L bracket, but are the bolts that hold it, captive, or are they likely to either slip inside the chassis rail or when re- tightening, go round and round. That’s really all I need to know. There’s enough float and flex in the exhaust system to just under the bobbin nuts and lift the system off of them and for extra ground clearance you can chop some of the thread off the lower stud which makes fitting them easier still.
The chassis fixings are captive Well yes and no. They are formed of two studs welded to a plate and fitted from the inside of chassis, through holes drilled just behind rear cross member. If side pipes are spec'd on the 3.7 Roadster at least, the holes are drilled forward of rear chassis member to accommodate the shorter silencers. Unfortunately once all the trim, seats and belt fixings are in it's too onerous a task to move them I found.
