2 members (JohnHarris, TalkMorgan), 345 guests, and 96 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 2 of 16 1 2 3 4 15 16
My 2011 4/4 has a redundant push switch, on the dash, which is designed for the not fitted Air Con. Caution if you are thinking of using this button for fog lights. Try pushing it on with the engine running, then turn on the fan. Magic the button lights up, which methinks means that the pcb is wired/programmed in some way that would interfere with your planned use. Mind you every morgan is different šŸ˜Ž
Rog #761549 14/11/22 10:34 PM
Originally Posted by Rog
As far as I can seen the auxiliary front light wiring/switching doesn't involve anything to do with the PCB Rog mentions or indeed any relay.
Richard I haven’t see anything ā€˜concrete’ to suggest that is not what they have done. The front fog functionality (ie.not on with main beam) could have been built into the pcb utilising those little 12A pcb mounted relays scared
Please please let me be wrong…..
At the end of the 2016-2014 Classics parts book Rog there are various wiring schematics including three variants of the chassis loom with the first two attributable to earlier models it seems since the last one is dated 2007.
In any case on all three a front fog light switch connector is shown fed from the o/s sidelight fuse12. With the switch present this feeds through to the front wings each side. The o/s fuse together with the n/s one are fed directly by the stalk light switch when sidelights selected. This stalk switch is fed by a further fuse 18 to protect it, in turn fed by fuse 8 in the high current set which fuses the main fuse box. All of latter are fed directly from the battery. Phew!
Draw your own conclusions but I cannot see any intervention by PCB. The rear fog light circuit is a different matter of course to comply with regs.
Originally Posted by Montegue
Excellent advice from you both, Richard & Rog.
Yes, I intend to use Monty's column switch and the Morgan wiring, so it’s helpful to know the PCB that controls that circuit can be problematic, I assume/pray the circuit does also include a traditional make/break relay so it would be helpful to know where it lives?
Not sure why you would want to do that given the extra wiring Dave, but your call. Remember extra load's will be placed on headlamp and maybe dip switch, assuming you use halogen bulbs for both.
My advice has been based on the assumption you would source and fit the optional front fog switch and use the existing plug and play behind dash connector. This is what MMC would have done if front fogs or spots had been spec'd on new car. If you want to go this route, once you have sorted and wired the lights at the front, you will need to drop the dash. There you should find an unused 8 pin connector with just two wires leading to it, red/orange and wait for it, blue/yellow, and yes have traced this to the front of car wink As a test it will do no harm just to jumper these two connections together to simulate simple toggle switch and check to see your fogs light up. Note you will need to have sidelights on first though.
As far as I can see the auxiliary front light wiring/switching doesn't involve anything to do with the PCB Rog mentions or indeed any relay.
Hi Richard,
I really should take the time to read your instructions better, 'My Bad' as the youf would say getcoat
After reading and digesting your latest comments they promoted me to look back at your earlier instructions.... and low and behold I found this.....
"To this end, no the blue/yellow wires are not permanently live they are controlled by the dash wiring which is already in place to an unused connector, allowing the optional fog light switch to be added"
I never expected the wires to be permanently live as this would be deadly, but I was so convinced they were controlled by the fog light switch on the stalk I totally overlooked your critical pearl of wisdom above doh
I can now see why Morgan went with blue with a yellow trace, I suspect it's because the wires were intended as dual purpose, i.e they could be used with the auxiliary switch to control either a set of driving lights, or a set of fog lights depending on what was fitted. It could also explain why Rog talks of PCB failures, if someone say took the a +12v off the rear fog light to power two front fog lights thinking this was a way to use the stalk fog switch to power all three lights but failed to appreciate the PCB was never designed to carry that level of load, I can totally see why it could fry the board.
So, to control my new front fog lights I now need to source and fit the optional auxiliary light switch, and then use the existing plug and play connector block behind the dash I actually had no idea existed, right up until you drummed it into my thick skull! If that's the case I'd be super grateful can you link me to where I can buy the switch that comes with the right connection, and give me a few pointers on exactly where under dash I should go searching for the mystery connector block, if at all possible a photo of said connector block would be a massive help too camera
I think you've saved me a lot of head scratching, after finding the blue wires with a yellow trace my next step would have been to put my multimeter on them with the headlights and the stalk mounted fog light switch on too, I would have then assumed the circuit to be faulty and may have even progressed to running the live feed for my new front fogs off the rear fog light relay which by the sound of it may not have ended well for me or Monty frown
Many thanks for all your help Richard, if you do have a photo of the connector block and can link me to the right switch I'd be very grateful indeed notworthy
While Richard's existing wiring option seems by far the best way to proceed, if it does turs out my loom wasn't built with the blue/yellow wires here's another logical approach from Jon (CooperMan), although as I'm powering fog lights I'd be triggering the additional relay from the dip beam circuit not the high beam circuit as Jon has correctly used for his driving lights.
Like Jon I have no aircon, so that 30a fuse protected feed would make a logical choice to repurpose for the high amp +12v supply for my fogs, I have the aircon switch in my dash so I assume if I'm repurposing the aircon fused circuit I could also turn on my fogs with this switch? However, to ensure I blow the fuse before I overheat my additional fog light wiring I would have thought replacing the 30a fuse with a 20a fuse would be more appropriate.
John, just checked my old S1 wiring diagram and as suspected there are no fuses or cables marked up as Aux lights
I used the 30amp Aircon feed to the 8 way bulkhead fuse box (as I had no aircon) mounted a relay below & took the 'trigger' wire off high beam, worked well
Andy MOT, may be able to confirm but my MOT chap said if linked to hi-beam, the spot lamps did not need testing for aim, if on a separate switch they did (as the driver could leave them on)
I found the above here....
http://www.talkmorgan.com/ubbthreads.php/topics/555419/2018_Roadster_fog_lights
Either way I’ve now completely moved on from my original assumption that I’d be using the stalk switch, my new fog lights will definitely need a separate auxiliary switch to control them. Hopefully I do have the blue/yellow wires as it seems Morgan built this circuit into the loom to make exactly what I’m trying to achieve a straightforward and safe exercise for their dealers looking to retro fit additional lighting to a customer’s car.
You seem to have the gist of it now Dave. MMC provisioned for the optional front fog or driving lamps to be plug and play. Don't have any pics of dash wiring or even where the optional switch is supposed to fit (is it one of the group of four between dials?) but hopefully Rog with his similar age +4 can help here.
The wiring schematics I refer to elicit quite a lot of info if you know where to look. To this end I can tell you the switch connector you are looking for routes out of the chassis loom at the same point as its multiway dash connector but with 400mm long wires (red/orange and blue/yellow), so probably cable tied out of the way whilst unused. You may be able to see it from under the dash, but again Rog may be able to help.
If you have difficulty sourcing the correct switch to match connector, any single pole on/off switch will suffice and you could connect direct to the two wires after chopping off connector. Pardon me for stating the obvious but disconnect battery before dropping dash.
Rog Offline
An interesting thread Richard. Sorry I can’t help with either request. I’ve never considered fitting fogs before but mind you those Marchals do look very attractive…
Can’t help thinking if I was going down this road I might leave the ā€˜plug and play’ alone and use new wiring, relay, fuse and switch.
Roger
Think it’s already been said, but that (almost) redundant aircon switch, must have some existing connection with the heater fan as if depressed, it will show the yellow snowflake symbol lit up, whenever the blower is on. Just saying…as you might find everytime you put the fogs on it might start the blower or when you put the blower on, it might start the fogs!
Doug
2011 Plus 4 in Rich Maroon
1972 750 ā€œComDomā€ sprinter
1958 Triton 650
1992 Triumph Trophy 900
Rog #761667 15/11/22 09:50 PM
The above definitely remains an option, but only if the blue/yellow wires and the now infamous yet unphotographed behind the dash switch connector block both remain elusive sherlock
Surely using the existing rear fog light circuit to energise the tiny coil in a standard 30a 12v relay isn't going to do any damage to the PCB, after all it's only going to be pulling 150 - 200 mA thinking
Like this all three fog lights would be triggered by the same fog light switch on the stalk and the PCB would only see 200mA tops, it would also retain the logic circuit where the fogs can only be deployed with the headlights switched on, and the 20a fuse protected live feed to power the fog lights would come direct from the battery ensuring an unimpeded current supply from source.
The only disadvantage being I'd need to build and run a simple separate loom for the fog lights and relay, assuming it exists I’d still far prefer to use the existing auxiliary light wiring Morgan intended to power driving or fog lights, but if it proves problematic to locate at least there’s plenty of other safe options to light up my lovely Marchals thumbs
Rog Offline
It might be in the background here? Lurking next to the fag lighter socket that was located in the side wall of the glove box (it’s an old pic of a mod to re calibrate the fuel gauge that I did to my 2006 car).
Roger
Rog #761678 16/11/22 08:02 AM
Nice one Rog thumbs
To make 100% sure I've correctly understood what you're referencing here, I've rotated the photo and marked the connector I believe you've identified with a red arrow.
The green arrow points to what may well be the blue wire with the yellow trace, I've zoomed in below and it does look like the tracer in the blue wire could be yellow in colour thinking
Actually if we zoom in even closer and turn up the colour stauration it seems even more likely the tracer is indeed yellow sherlock
Please let me know if I'm looking at the right connector, also if someone could link me to a post that covers dash removal I'd be very grateful.
cheers
