2 members (Vansrv6, Montegue),
294
Posts837,277
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
I wish you had told me sooner Bernt Doug, we need a picture.. I did Rog, I did! a pillar sealYou are a real gentleman that doesn't read any praise for you
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Sorry Bernt, I missed the thread.  One hundred lines. “I must pay better attention….” I will consider myself reprimanded
Roger 2011 Plus 4
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
I wish you had told me sooner Bernt Doug, we need a picture.. I did Rog, I did! a pillar sealYou are a real gentleman that doesn't read any praise for you  Correction made to link above.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Not sure what Doug is referring to but this is picture of mine which look very similar to your new ones Rog. ![[Linked Image]](https://i.imgur.com/hgZEBUN.jpg) It's the outer lip that has split at the bottom. Richard, I noticed when new my seals were applying a lot of twist to the lip as the sidescreen frame closed & opened over it, I put a steel ruler against it and carefully trimmed a tiny sliver off with a scalpel, which solved mine, plus I lube them occasionally with a bit of clear Autoglym tyre dressing on the 'fin'
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Thanks Doug and well done with the pic  Job done but I only had some EPDM sheet. ![[Linked Image]](https://dl.dropboxusercontent.com/s/zcp42va79lnnwam/top%20seal.jpg) A very neat job!
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Not sure what Doug is referring to but this is picture of mine which look very similar to your new ones Rog. ![[Linked Image]](https://i.imgur.com/hgZEBUN.jpg) It's the outer lip that has split at the bottom. Richard, I noticed when new my seals were applying a lot of twist to the lip as the sidescreen frame closed & opened over it, I put a steel ruler against it and carefully trimmed a tiny sliver off with a scalpel, which solved mine, plus I lube them occasionally with a bit of clear Autoglym tyre dressing on the 'fin' Thanks Jon, will try that with the new ones although I do lube them occasionally.
Thanks Doug and well done with the pic  Job done but I only had some EPDM sheet. ![[Linked Image]](https://dl.dropboxusercontent.com/s/zcp42va79lnnwam/top%20seal.jpg) A very neat job! Thanks! I hadn’t really thought about sealing here before. I don’t know how effective the harder material will be compared to the squishy foam but the roof appears to sit on it nicely, so far....
Roger 2011 Plus 4
Pulling the old seals off leaves a strip of the self adhesive material firmly stuck to each inner edge of windscreen pillar. This is extremely difficult to remove until I discovered this method:
Soften remaining material with brake cleaner then start peeling from edge with finger nail. Once started continue with downward thumb pressure. The material should peel off cleanly rolling into a ball which can be picked off when large enough. Clean any residue with paper towel soaked in brake cleaner. This leaves clean surface ready to accept new seals.
And a pic of the front rail sat on the rubber pad with the roof locked down. If nothing else it should help protect the paint... ![[Linked Image]](https://dl.dropboxusercontent.com/s/gwfr3pkagul956q/topseal2.jpg)
Roger 2011 Plus 4
Posts: 1,042 Likes: 148
Posts: 1,042 Likes: 148 |
Damn you Rog, another thing I now have to buy for Monty  Seriously though, thanks for sharing, these seals look like a 'must have'  Only last week I added a run of self adhesive neoprene up the inner leading edge of both side screens to create a neoprene on neoprene seal, this eliminated the rattles and created a better seal reducing wind noise, but these lip seals look like a way better solution so I've just bpoght a pair. Let's hope the supplier is more effective with my seal order than they were getting a pair of spot light mounts to me, despite confirming at the start of the process the brackets were in stock, over three weeks and four telephone calls later I was forced to ask for a refund and buy an alternative set from Librands  Fingers crossed the seals will be with me for Saturday as I'm prepping Monty for a run to Goodwood on the Sunday.
