0 members (), 107 guests, and 35 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
E
E
Hi
I am looking for a Ford type 9 5-speed gearbox to go in my 1981 4/4 with the Ford 1600 crossflow engine.
Somerset based
Anyone out there have one?
Many thanks
Instagram @eastertown
1980 Morgan 4/4
1988 Morgan Plus 8
Porsche 986 Boxster S
Well, as it happens I do have s type 9, surplus to requirements, and not too far from you either, just down the road near Taunton. How's that for luck?
It was a new gearbox, but now with 2000 miles and was mated to a Zetec engine, so should just bolt on to your x/f. It actually comes with an aftermarket hydraulic clutch, but that doesn't have to be used if you want to retain the original cable actuated clutch. I believe I may also have a cast iron bell housing somewhere too. It has standard ratios, but I would suggest that whatever gearbox you buy, you have it uprated to a long 1st and 2nd, it makes such a difference. It is quite expensive, but well worth it in the end.
I estimate that it is probably worth about £750 ono.
PM me if you are interested and want to come down and see it.
Paul.
