0 members (),
334
40
Posts837,990
Posts: 15 |
While fitting the rear shock absorbers I noticed that the plywood inner wing on one side seems to have lost the black under seal/ coating that is still there on the other side. What would you suggest I use to replace it. Thanks
Posts: 27,835 Likes: 760
Posts: 27,835 Likes: 760 |
Black underseal is what I use from Halfords bought many years ago.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
I used some underbody Schutz.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
I'm presently using this aerosol black underseal with waxoil to repair small areas of underbody corrosion. It's excellent for getting into tight corners then staying there. Should work fine on wood. ![[Linked Image]](https://i.ebayimg.com/images/g/HWkAAOSwYsBdhxlm/s-l300.jpg) Keep well clear of outer bodywork though. It's very black and very sticky!
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
^^^ as above .... because I have a big can in the garage I use the brush on version ..... you can thin it with white spirit or mix it with ordinary Waxoyl to creep into joins and soak in well.
