2 members (Chris Cosher, Vansrv6), 272 guests, and 37 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#763101 02/12/22 03:45 PM
While fitting the rear shock absorbers I noticed that the plywood inner wing on one side seems to have lost the black under seal/ coating that is still there on the other side. What would you suggest I use to replace it. Thanks
William s #763103 02/12/22 05:41 PM
Black underseal is what I use from Halfords bought many years ago.
William s #763108 02/12/22 06:12 PM
I used some underbody Schutz.
William s #763115 02/12/22 06:56 PM
I'm presently using this aerosol black underseal with waxoil to repair small areas of underbody corrosion. It's excellent for getting into tight corners then staying there. Should work fine on wood.
Keep well clear of outer bodywork though. It's very black and very sticky!
William s #763116 02/12/22 06:58 PM
^^^ as above .... because I have a big can in the garage I use the brush on version ..... you can thin it with white spirit or mix it with ordinary Waxoyl to creep into joins and soak in well.
