1 members (+8Rich),
271
40
Topics49,911
Posts838,149
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
That reminds me, beware of combined fridge/freezers in a garage. The single thermostat is usually in the fridge compartment set at say 3°C. When garage temperature drops below, the compressor never comes on so food in freezer part gradually defrosts! Mine is in the garage and has a winter switch on it, leaves the internal light on dimly to encourage the fridge to keep working. No probs so far.
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
That reminds me, beware of combined fridge/freezers in a garage. The single thermostat is usually in the fridge compartment set at say 3°C. When garage temperature drops below, the compressor never comes on so food in freezer part gradually defrosts! Mine is in the garage and has a winter switch on it, leaves the internal light on dimly to encourage the fridge to keep working. No probs so far. It's because sausages are frightened of the dark
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
You guys give very useful tips to look after, thanks a lot.
Posts: 528 |
Obvious I know BUT if you are using the car (as I am) when its bright but very cold, check your tyre pressures.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Obvious I know BUT if you are using the car (as I am) when its bright but very cold, check your tyre pressures. This is very important. Extreme cold can drop pressures into the mid teens.
Obvious I know BUT if you are using the car (as I am) when its bright but very cold, check your tyre pressures. This is very important. Extreme cold can drop pressures into the mid teens. If I'm not using the car for a few months over the worst salty part of winter, I bang the pressures up to 40psi as it helps stop flatspots and sidewall distortion
Posts: 528 |
Obvious I know BUT if you are using the car (as I am) when its bright but very cold, check your tyre pressures. This is very important. Extreme cold can drop pressures into the mid teens. As an aside from my earlier post. I was promted by my low Tyre pressure warning on my Merc GLE. Checked all car tyres as follows Merc GLE all down 5-6 lbs Merc SL down 4-5 lbs Morgan Plus 4 down 5 lbs.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Yep, same here. In the cold snap before Xmas my mini told me to check the tyres, they were all down by 5 psi.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Tarka is in the garage with the hood up and the side screen panels open. I'm fortunate that condensation isn't a problem as the garage was built so that an owner could convert it to rooms, if wished, so the walls are either shared with the house or insulated cavity walls, The window is double glazed and the roller shutter is also insulated. It has never dropped below 5c and is normally at 10 to 12c in winter.
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Ditto on tyre pressures. All 3 cars dropped by c 5c
