Topics49,847
Posts837,391
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I always put a large plastic bag over the engine bay (under the bonnet) before washing to protect the electrics under there - don’t forget to remove it after! There’s a lot of water goes through the louvres when washing. Even so from time to time on start up after washing the auxy drive belt squeals briefly.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 9 |
So much knowledgeable and valuable advice in such a short time - many thanks to all.
Once the rain stops here, I'll take a closer look at the fuse box in the daylight and hopefully actually locate the battery. Then I have someone coming over later with the necessary electrical gubbins to check whether the battery is dead or whether there's another problem. It's a 2012 model, so the battery may well have been original and well past it's sell-by date.
Thanks again for all the sage advice. I may be a mechanical novice, but the support network is excellent.
4-seater V6 3.7 Roadster.
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
Don't forget that every time you start the car it takes approximately 20 mins to replace the charge you have used to start it.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Thanks again for all the sage advice. I may be a mechanical novice, but the support network is excellent. If when you find the battery it's a 'Banner' brand then most likely the original & at 10 years old it's had it...buy a new one for peace of mind and reliability
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
+1  Don't worry about checking it if original, just replace.
Posts: 9 |
Battery found (not in any of the places suggested, this is obviously a special build) and replaced. All seems hunky and dory.
Thanks again for sage advice.
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
now where was the battery ?
Clemens
PlusFour Red Baron MY 2022
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Sounds like good news.
And like Clemens, I would love to know where they hid the battery.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
And is the problem solved?
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
As a matter of curiosity I still have the original battery at nearly 11 years old. I keep it on a battery minder charger that I actually ordered with the car when it is, or will be, in the garage for more than a week. Started today without any issues. We just had to replace the battery in the shopping trolley (a VW Polo) which now 6 years old. Nowhere near as good as the original Banner in the Morgan.
