2 members (TBM, JMcL),
340
86
Topics49,847
Posts837,389
Posts: 8 |
Latest £214.00 worth of specialist oil made absolutely no difference.Car going back to Revolutions next Thursday for investigation and poss rebuild.I,ll keep you posted.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Daft question but has the prop shaft been greased. On my 2014 Roadster there was no access to the front UJs. Having cut holes in the gear box tunnel & greased the front UJs the car is far smoother. I guess it hadn't been done since new in 2014 & 8 years.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Sorry but you were warned
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
If you end up having to have the diff and rear axle rebuilt I can heartily recommend a Quaife ATB diff. I've had one in my 4/4 since 2012 and I reckon it's brill.
Posts: 8 |
Hi guys,my howling diff saga now has an end. Took the car back up to Revolutions in Perth where Paul the head technician and myself took the car for an exploratory test drive.Paul agreed that there certainly was a problem and "you could play a tune on it using the throttle. I left my Morgan with them for investigation. They identified the problem and shipped the back axle down to a specialist in the Blackpool area for a rebuild. The axle was returned,rebuilt with a new crown wheel and pinion then refitted back in the car. Travelled back up to Perth on Wednesday to collect my Sport and then drove home in a transformed car. Top marks to Elliot,Angus and Paul for sorting this for me and if you need good old fashioned service I highly recommend Revolutions.
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
Grant, that's a good story of great service from Revolutions plus you are back on the road  Always good to hear the outcome of these mechanical issues so thank you.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Glad you have the diff issue sorted, I bet that skinned the wallet
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Glad you have the diff issue sorted  Am sure that is a relief. Hopefully more time in car will prove it is gone for good.
David
MY22 Plus Four, Alligator (AML Racing) Green ! 😍
I'm glad it is sorted.do you know the cause
