2 members (TBM, RedThree), 197 guests, and 32 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
Black Rat
Black Rat
That reminds me, beware of combined fridge/freezers in a garage. The single thermostat is usually in the fridge compartment set at say 3°C. When garage temperature drops below, the compressor never comes on so food in freezer part gradually defrosts!
Mine is in the garage and has a winter switch on it, leaves the internal light on dimly to encourage the fridge to keep working. No probs so far.
Keith
2013 narrow bodied + 4 Ruby.
It's because sausages are frightened of the dark smile
DaveW #764958 20/12/22 07:41 PM
You guys give very useful tips to look after, thanks a lot.
Heinz #765138 22/12/22 03:44 PM
E
E
Obvious I know BUT if you are using the car (as I am) when its bright but very cold, check your tyre pressures.
DaveW Offline OP
This is very important. Extreme cold can drop pressures into the mid teens.
DaveW #765299 23/12/22 09:23 PM
If I'm not using the car for a few months over the worst salty part of winter, I bang the pressures up to 40psi as it helps stop flatspots and sidewall distortion
DaveW #765610 27/12/22 02:12 PM
E
E
As an aside from my earlier post.
I was promted by my low Tyre pressure warning on my Merc GLE. Checked all car tyres as follows
Merc GLE all down 5-6 lbs
Merc SL down 4-5 lbs
Morgan Plus 4 down 5 lbs.
Yep, same here. In the cold snap before Xmas my mini told me to check the tyres, they were all down by 5 psi.
DaveW #765616 27/12/22 03:46 PM
Formerly known as Aldermog
Tarka is in the garage with the hood up and the side screen panels open. I'm fortunate that condensation isn't a problem as the garage was built so that an owner could convert it to rooms, if wished, so the walls are either shared with the house or insulated cavity walls, The window is double glazed and the roller shutter is also insulated. It has never dropped below 5c and is normally at 10 to 12c in winter.
DaveW #765617 27/12/22 03:55 PM
Ditto on tyre pressures. All 3 cars dropped by c 5c
