Topics49,841
Posts837,318
Posts: 36 |
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Hope you don't mind but have taken a couple of your photos to be displayed alongside each other Andrej. I particularly like how you have changed the engine mounts from OE style. ![[Linked Image]](https://i.imgur.com/QUPl1FS.jpeg) to these large silent blocks. ![[Linked Image]](https://i.imgur.com/kCF2NHb.jpg) I just have a question though as it's not clear on photo. Do the circular blocks need/have spreader washers top and bottom or is the load somehow spread by internal steel bush to the whole surface of rubber?
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
What is the voltage regulator/rectifier off, or part number? Does it match up to the loom without much re-wiring? I notice you had a Harley one earlier, any advantages with the new one?
I like the look of the engine mounts and chassis mods, although other than the two known locations for chassis cracks, things seem to be OK with that. Maybe an engineering overkill but that's not a bad thing?
Thanks Andrej
Posts: 22 |
Fantastic work Andrej! I'm always amazed at the level of ingenuity and skill that people can have.
Posts: 557 |
Brilliant work!! Any chance you can share more details about those pipes dimensions and silent-block specs?
Thank you!
Fantastic work Andrej! I'm always amazed at the level of ingenuity and skill that people can have. Excellent
Posts: 36 |
The steel pipe is completely simple, IDxOD 35x25mm, as long as you can push inside... The Morgan rectifier went wrong first, then I had a Harley, that went wrong too. Now I put a small from motorcycle Suzuki, we'll see how long it lasts... :-)
