2 members (Vansrv6, Montegue),
294
Posts837,277
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Hi Nippy, have a look at this.... https://youtu.be/Gtp3Tf8fYVE
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
This was from Morgan Ltd. ![[Linked Image]](https://www.tm-img.com/images/2022/12/05/crankNutTotque.jpeg) Great find - thanks for sharing.....
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
Just noticed by chance on PB website that Phil is no longer offering the full Centa conversion unless its hand fitted by himself to the engine at his Lancaster workshop....
Phil is now only offering the PB inner rotor upgrade option as a third party/non UK fit option (unless you ship the engine direct).
I have actually only been fitting our own modified inner rotor and not the full Centa for past 4 months due to the issues with the PB Centa/crankshaft fit.
So if you have a PB Centa kit waiting to be fitted by a third party then your choice but I for one would just go for changing the inner rotor and leaving the original outer Centa in place attached to the crankshaft.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
That is what I did, since the rear crank seal was not leaking oil I figured why mess with it.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
That is what I did, since the rear crank seal was not leaking oil I figured why mess with it. wouldn't a step by step (with pictures) be great
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
That is what I did, since the rear crank seal was not leaking oil I figured why mess with it. wouldn't a step by step (with pictures) be great Phil has done a number of videos showing how it is done, https://www.youtube.com/@morganthreewheelerworkshop1189/videos
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
I wonder where he got that torque figure? I just looked at several charts for graded fasteners, and for bare (unplated and un lubricated) the torque for Grade 5 is about 475lbs/ft. For plated and lubricated bolts the torque is more like 350. For Grade 2 it's about half that, and for grade 8 about 40% more. Bolts all have rolled thread which are generally stronger than the machined threads as found on the crankshaft. So to come up with a suitable torque for a 7/8" machined thread in an unspecified steel would be a non S swag, IMO. Perhaps Phil was able to determine the type and hardness of the crankshaft and extrapolated from there?
The thickness of the nut may or may not have an impact on the torque figure. I was taught you need at least 1 diameter (of the male thread) of thread engagement to achieve full strength in a bolted joint, with 1.5 diameters preferred in order to provide a margin of safety. So if the 'thin' nut is roughly 7/8" tall then there is little to be gained by a deeper nut. Sorry for the delayed comment - I haven't been on here for a bit. Figures from here will give a rough guide https://www.norbar.com/Portals/0/downloads/TorqueValueGuide.pdf one should read the notes at the top of the page and realise that torque wrench settings are very much dependant on surface finish of the thread - plating - lubrication - washers and a lot of other things which can be controlled in a production line environment but not when we are doing a one off installation in a small workshop. I have made assumptions in the absence of information from manufacturers. I assume the material to have an ultimate tensile strength round about 50 tons / sq in (S grade) and you can see the reading recommended for 7/8 UNF S grade threads is 433 Lbf ft. The reason for getting this right is that the assembly forms a compound bar to withstand the sideways thrust of the centa rollers - something the original crankshaft was not designed for. I don't recall telling anyone to discard the flat washer - you should discard the spring /star washer - there is no point in locking the nut to a flat washer which is not locked to the shaft. Hope this helps folks to understand what is going on inside that bell housing - feel free to contact me if you want further clarification of my ramblings. Phil
Posts: 450 Likes: 1
Sorry again for the delayed reply. As a result of a small percentage of failures due my assumption that a well made item would fit on every crankshaft - which turns out not to be the case - I have had to re think the job. I recommend that, If you have one of my kits waiting to be fitted, then you should bring it to me or find a properly skilled mechanical fitter to install it for you - that person may find that the fit is not good enough in which case you should contact me for a solution in the form of an undersized hub to fit your shaft. whoever is fitting the hub to your shaft should look here for a description of the process https://www.youtube.com/watch?v=UAnLJGKJDsM Please do not make the assumption that if it feels tight going on that it will be OK - you must inspect the splines carefully to see marks where it fits tightly especially on the flanks of the splines - this will require pulling it on and off several times - tedious but there is no safe alternative. As always I am here for advice please feel free to get in touch although I don't spend much time on these pages so a mail or phone call would be better. Phil
Posts: 62 |
That is the recommended MAXIMUM torque load in the chart, a bit close to the wire in my view
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I don't think any crankshafts have broken under excessive torque on the nut. The problem seems to relate to poor spline fit due to crankshaft machining variations that have caused some play, even with the high torque. I cannot see that reducing the torque of the crank nut would help anything.
