6 members (nestor59310, Barkingdog, MartO, IcePack, DaveW, DCH), 301 guests, and 38 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,357
Christoph
Page 2 of 4 1 2 3 4
My is summer 2013 :-)
Hope you don't mind but have taken a couple of your photos to be displayed alongside each other Andrej.
I particularly like how you have changed the engine mounts from OE style.
to these large silent blocks.
I just have a question though as it's not clear on photo. Do the circular blocks need/have spreader washers top and bottom or is the load somehow spread by internal steel bush to the whole surface of rubber?
thumbs
Nothing is needed.
The new silentblock is including metal plates for homogene force and that is all.
The rear monts are out, not more needed.
No vibrations, perfect drive :-)
Here the silentblock
https://www.skoda-diely.sk/nahradny-diel/114002280-silentblok-motora-ceska-prvovyroba-59.html
What is the voltage regulator/rectifier off, or part number? Does it match up to the loom without much re-wiring? I notice you had a Harley one earlier, any advantages with the new one?
I like the look of the engine mounts and chassis mods, although other than the two known locations for chassis cracks, things seem to be OK with that. Maybe an engineering overkill but that's not a bad thing?
Nothing is needed.
Thanks Andrej thumbs
I
I
Fantastic work Andrej!
I'm always amazed at the level of ingenuity and skill that people can have.
Brilliant work!! Any chance you can share more details about those pipes dimensions and silent-block specs?
Thank you!
Excellent cheers
The steel pipe is completely simple, IDxOD 35x25mm, as long as you can push inside...
The Morgan rectifier went wrong first, then I had a Harley, that went wrong too. Now I put a small from motorcycle Suzuki, we'll see how long it lasts...
Page 2 of 4 1 2 3 4
