8 members (Moggo, John V6, Hamwich, itsfrank666, LE52MOG, Grumpy2, GrandadC, Richardllll),
320
40
New
Topics48,365
Posts813,388
Members9,215
Posts: 1,013 Likes: 243
Posts: 1,013 Likes: 243 |
I had the first ride today with my other good side... as my wife.I guess I will have to do the same and add a gasket to the side screens in the back. thierry242 where did you get the piece of neoprene and how thick is it ?
Clemens
PlusFour Red Baron MY 2022
Posts: 239 Likes: 1
Posts: 239 Likes: 1 |
Morgan have a fix for the gales blowing into the car. They fitted mine with especially designed rubber seals. Not perfect but better. I would contact them and get some sent out to you. For £80k I don’t buy the “it’s a Morgan” phrase. It’s not difficult to design the car to stop that gale. Crikey I didn’t have it on my 4/4 or Roadster so gone backwards if you ask me. In addition where there are gaps there are leaks which is totally unacceptable. The car itself is fantastic but the little things let it down big time.
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Thank you Jonathan for your info. I will talk to my dealer. Will not be able to talk to MMC directly from Germany. I like the little things that you have to fix yourself at Morgan. That's what makes this car so charming to me. A Morgan is not a perfect car. Even if it is admittedly not a cheap vehicle. But that's just my personal opinion.
Clemens
Posts: 613 Likes: 15
Posts: 613 Likes: 15 |
It was on amazon , i am searching the link. I cut it in two with a good cutter and add a better double face scotch to fix it ![[Linked Image]](https://tm-img.com/images/2021/10/26/Screenshot_20211026-183730_Chrome.jpg)
The right sidescreen has less wind passing that the left side on my car
same on my car. I have added a piece of neoprene to decrease the air flow passing trough that gap ![[Linked Image]](https://tm-img.com/images/2021/10/26/20211026_173348.jpg) Therry did you tape over the Orginal seal with the neoprene seal or do I have a different version from the factory. This is what my side screen original looks like from the factory with a pre-existing gasket. Draught comes on the right side right bottom and on the left side left bottom ![[Linked Image]](https://tm-img.com/images/2023/01/15/B2AB0168-F4DD-4F61-86C5-B3A355B87983.jpeg)
Clemens
The right sidescreen has less wind passing that the left side on my car For me, it's just the other way around. My vehicle pulls more on the right side. And since this is the passenger side of a left-hand drive, I was tasked with a quick solution. True to the motto... happy wife ... happy life
Clemens
i didnt have that seal on my car , they copy what i did .
Posts: 239 Likes: 1
I didn’t have the seals on mine either but complained to Morgan about the wind and they retro fitted then for me. I think they are on all new cars now but they are far from perfect. Despite them telling me that had a specialist seal manufacturer design something especially for this car they do look like they copied yours 🤣🤣🤣
Posts: 193 Likes: 5
Posts: 193 Likes: 5 |
I requested these gaskets from my dealer. They have to be settled well. They must start from the door and end before the hood. If the seals are well placed, there is no longer any wind inside.
