0 members (), 318 guests, and 40 robots.
+8Rich 94
Posts837,276
Page 3 of 4 1 2 3 4
Mine were fitted at the Morgan factory and trust me they don’t get rid of the wind completely.
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
Originally Posted by gaston
I requested these gaskets from my dealer. They have to be settled well. They must start from the door and end before the hood. If the seals are well placed, there is no longer any wind inside.
Gaston would it be possible that you post a picture of your side screen. Then it would be to see how far in your solution the seal is attached to the top and bottom.
It would be interesting to know if there is a difference to the current standard solution of the company.
Clemens
PlusFour Red Baron MY 2022
the problem is that the shape of the sidescreens is not the same btwn cars from 2020,2023.
[Linked Image][Linked Image]
Thanks a lot Gaston 👍😎
Clemens
Clemens
If I understood Gaston correctly, my seal would have to go down a little further
Clemens
No, he's good down there. You have to check that it sticks well to the rear pillar of the car all the way.
I had to remove the leather seal for it to work well.
Gaston,
I don’t have a rear pillar that I know of - perhaps this is a translation issue( if so, my apologies!!) can you be more specific re the positioning of the additional neoprene seal,please.
Regards from Ireland!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Hello Robbie.
Sorry for the delay in answering your question.
have expressed myself badly
I must Before finally mounting your seals, you must close the door and check that this seal sticks well to the back of the door, otherwise the air will continue to enter. This seal is not necessarily glued to the leather of the side-screen..
You can see it in photo number 2.
Page 3 of 4 1 2 3 4
