2 members (Nickplus4, thelastgizmo), 401 guests, and 32 robots.
+8Rich 92
Posts837,284
Page 26 of 164 1 2 24 25 26 27 28 163 164
While I have the dash board out for refinishing, I had the switch panel powder coated.
T-Track 2 are imho a very good decision.
I am curious what your assessment will be!?
Me too! These arrived yesterday...
Originally Posted by C2RM
When testing the car Darren felt ...
He is very good. Has a great understanding of Morgan foibles. :-)
Black Rat
Black Rat
Fitted the Optimate 5 hard wired in this morning, hopefully wont get caught out in the next cold snap.
Keith
2013 narrow bodied + 4 Ruby.
On strike today so did my stint on the picket line this morning. Reassembled on of the Strombergs on the Plus 4. Got it started and set the idle on it, syncro'd the carbs but still running rich and fouling the plugs on acceleration. Needles are correct for a 3069 carb (2H) so next on the list would be check the float heights.
Got it hot enough to change the oil so dropped that and changed the filter - much easier since I converted to a spin off filter. Didn't have a replacement sump washer so annealed the old one on the gas hob
Bled the brakes and set the handbrake up.
Just awaiting amended logbook from Swansea before I can put it in for test
Arwyn
Worked on the refinishing of the dash board and rebuilding the wooden glove box. When I got home from the shop, this bit of automotive engineering art was on the front porch...
Have fun installing the new helical differential
Clemens
PlusFour Red Baron MY 2022
This is one of the jobs for the pros. Also switching from a 4.56 to a 4.10 gear set...
Greased the front end and checked the nuts & bolts.
Popped over to a friends today to fit him some replacement press studs in the interior, bit fiddly to hold all the components in place - but very satisfying to help a fellow Mog owner
