5 members (Morganmike, Pipmac, rossocorsa, JohnMat, RichardV6), 373 guests, and 107 robots.
+8Rich 80
DaveW 52
Topics49,866
Posts837,607
Page 2 of 4 1 2 3 4
Online NoMood
When I had mine, the first thing I did was remove the overlong bolt to allow operation of Q/R steering wheel. Good security feature. It's true you have to be careful it's fully engaged but pretty obvious when not I found.
I had fitted from new by dealer a full aftermarket screen but don't recall any gaps at bottom of pillar. The top bolt did allow attachment of aftermarket rear view mirror though.
The best mod I did was fitting the then available Stage 1 kit from MMC including pipes that allow retention of heat shields and S & S air filter. Apart from the sound the bottom end was smoothed out considerably with clean pull from 2500 instead of 3000 rpm.
Originally Posted by Ginmoggie
On a separate note, the previous owner had vinyl decals of his company logo added to the car - whilst I think they look quite nice, I'm not sure about driving a vehicle which advertises alcohol and am considering changing them for something more mainstream - what do people think?
If you keep them then I'd ask Norfolk Gin for some sponsorship or at least a few free bottles smile
Red Leader drive
They have nothing to do with you. So have them profesionally removed (don't just try and peel them off). Personalise your car to suit you.
Hello everyone. Just before Christmas I took delivery of a MY 17 M3W from Krazy Horse. ...
Welcome! Some nice driving roads in N Wales, although I hear the policing of speed limits can be a bit zealous!.
3. I have the heritage screen fitted and can see two gaps in the screen at the bottom of the centre alloy stem - what is their function?
I have the Fairbourne screen and no gap I have noticed, but note the car is designed for aeroscreens so the heritage screen does not "slot" into the body all the way from L to R - I suspect the gap is just due to Morgan not putting a gasket there.
I would think that your steering quick release was a Lifeline one Richard, they are better made than the later Traven items. Personally I would disable all steering wheel QR's but certainly the Traven ones fitted after April 2017. They have proven to be dangerous and have caused some accidents when the steering wheel unexpectedly comes off!!! All owners should read the article in this link:
https://www.mtwc.co.uk/wp-content/uploads/2019/10/QR-Steering-Wheel-Problems.pdf
As for the gap at the base of the screen, put a bead of clear silicone sealant in it. Sorting the restrictive exhaust is one of the best improvements for a M3W. The "bafflectomy" works well but can be very loud and there are more noise restrictions on their way.
Enjoy your M3W, I remember seeing it at a show once, very tidy.
Originally Posted by Taffmog
Hi Ginmoggie, I can't add anything to the above comments, I too was considering an exhaust upgrade, probably a bafflectomy but considering the low mileage the car does I've left well alone, if you do an exhaust upgrade modify the air filter too. Personally I would remove the gin decals but the rest of the car is lovely. I'm a Denbigh lad and haven't moved more than 10 miles away so must meet up when our cars get back on the road, finally if your car is on SORN don't forget to drain the oil either in storage or before starting the engine, don't ask me how I know!
Thanks for the advice Taffmog. I'm still a Denbigh lad so we're practically neighbours and in fact you may be responsible for my choosing the M3W - couple of summers ago I was driving with my wife through Trefnant in the direction of St Asaph when a three wheeler passed the other way on the bend by the old AA box. I remember saying 'I've got to get one of them when I retire'. A meet up sounds great.
2017 M3W
Thank you all for the candid opinions regarding removing the decals - I'm inclined to agree and have been in touch with MMC about some stock decals wich they are awaiting delivery of.
@ PaulV - North Wales did indeed have a reputation for speed enforcement which harks back to the days of an over zealous chief - in truth, I don't think it was any worse than other regions but the police were in no rush to dispel the 'myth' as it was a cheap deterrent.
Here is a picture of the gaps on another car heritage screen - I wondered if they're to equalise negative pressure or something but as no other car seems to have this your explanation sounds more plausible.
2017 M3W
I have often fitted aftermarket pipes to bikes over the years but this has been for the benefit of aural gain - by the sounds of it, there are real mechanical benefits for adding stage 1 pipes to the M3W so I'll go ahead and get a set. Is home fitment straight forward?
Yes, it's a straight-forward DIY job. Soaking the joints & clamps between the main exhausts and headers with penetrating oil for 24hrs before you attempt to separate them makes life easier.
Andy
Ginmoggie does you car have a batten under the front edge of the drivers seat to lift it a little? This improves comfort & is easy to do. If long of leg a steering wheel spacer is worthwhile.
Nice vintage style luggage box. May not be practical on high speed long journeys but definitely has a genuine nice look at short journeys.
Any idea where I can source one please?
M3W: 2017 green
Caterham: 2003 yellow
Evora 400: 2016 black
SL500: 2005 blue
HD Breakout: 2020 red
Page 2 of 4 1 2 3 4
