Topics48,346
Posts813,048
Posts: 703 Likes: 70
Posts: 703 Likes: 70 |
DIY day at a friend's who owns a 2010 Morgan 4/4 sport, 1.6l Sigma engine The Target is to mount an aluminum radiator from Mulberry Fabrications Ltd, reference MFRAD06. the build quality is very good, the mounting kit is very well designed, the original fan fits the new radiator perfectly : ![[Linked Image]](https://zupimages.net/up/23/07/5vn2.jpg)
Lille - North Of France
Sold : MTW 2012 / Mog 4-4 Sport 2010 / Mog Roadster V6 2008 Mog Super3 2024
you have to shorten the water hoses a little so that they fit perfectly, nothing complicated... : ![[Linked Image]](https://zupimages.net/up/23/07/j946.jpg)
There is plenty of space to position the radiator in the right place, once the grille is raised, the radiator is perfectly protected from gravel impacts : ![[Linked Image]](https://zupimages.net/up/23/07/3c7t.jpg)
Posts: 28,416 Likes: 178
Posts: 28,416 Likes: 178 |
Looks good
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 7,923 Likes: 217
Posts: 7,923 Likes: 217 |
Good result I found it relatively easy to fit my very similar SiFab radiator without removing cowl or grill. The extra space is just needed to remove the OE rad, but if you separate the rad from fan and it's cowling in situ, the former just slips down. New rad assembled with fan then slips in upwards from below easily. I admit having a ramp makes this easier though.
Posts: 1,952 Likes: 41
Posts: 1,952 Likes: 41 |
Good result I found it relatively easy to fit my very similar SiFab radiator without removing cowl or grill. The extra space is just needed to remove the OE rad, but if you separate the rad from fan/housing in situ, the former just slips down. New rad assembled with fan then slips in upwards from below easily. I admit having a ramp makes this easier though. +1
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
+1 well done. Great for peice of mind I found.
When mounting the radiator, I noticed these beautiful suspensions. it must be the SSL RS Morgan Front Suspension decry in the forum : ![[Linked Image]](https://zupimages.net/up/23/07/o4t6.jpg)
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
^ Yes, that's the SSL upgrade
Posts: 62 Likes: 1
Posts: 62 Likes: 1 |
Hi Jon what in the photo tells you it is a SSL suspension up grade,my Australian delivered 110 year anniversary model has the same looking suspension ie spring and shock colors etc. what little paper work I have states that the suspension is set up for Australian conditions. The rear shocks are same appearance but red. On a separate note can some one confirm shock adjustment ie screw in for harder and screw out for softer. Thanks Colin
2019 Plus-4 Royal Guardsman Blue 2020 Subaru 2.5iP 2014 Toyota Landcruiser 200 series 4.5l diesel
