Posts837,951
Posts: 875 Likes: 157
Posts: 875 Likes: 157 |
DIY day at a friend's who owns a 2010 Morgan 4/4 sport, 1.6l Sigma engine The Target is to mount an aluminum radiator from Mulberry Fabrications Ltd, reference MFRAD06. the build quality is very good, the mounting kit is very well designed, the original fan fits the new radiator perfectly : ![[Linked Image]](https://zupimages.net/up/23/07/5vn2.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
you have to shorten the water hoses a little so that they fit perfectly, nothing complicated... : ![[Linked Image]](https://zupimages.net/up/23/07/j946.jpg)
There is plenty of space to position the radiator in the right place, once the grille is raised, the radiator is perfectly protected from gravel impacts : ![[Linked Image]](https://zupimages.net/up/23/07/3c7t.jpg)
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Looks good
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Good result I found it relatively easy to fit my very similar SiFab radiator without removing cowl or grill. The extra space is just needed to remove the OE rad, but if you separate the rad from fan and it's cowling in situ, the former just slips down. New rad assembled with fan then slips in upwards from below easily. I admit having a ramp makes this easier though.
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
Good result I found it relatively easy to fit my very similar SiFab radiator without removing cowl or grill. The extra space is just needed to remove the OE rad, but if you separate the rad from fan/housing in situ, the former just slips down. New rad assembled with fan then slips in upwards from below easily. I admit having a ramp makes this easier though. +1
Posts: 27,831 Likes: 757
Posts: 27,831 Likes: 757 |
+1 well done. Great for peice of mind I found.
When mounting the radiator, I noticed these beautiful suspensions. it must be the SSL RS Morgan Front Suspension decry in the forum : ![[Linked Image]](https://zupimages.net/up/23/07/o4t6.jpg)
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
^ Yes, that's the SSL upgrade
Posts: 62 Likes: 1
Posts: 62 Likes: 1 |
Hi Jon what in the photo tells you it is a SSL suspension up grade,my Australian delivered 110 year anniversary model has the same looking suspension ie spring and shock colors etc. what little paper work I have states that the suspension is set up for Australian conditions. The rear shocks are same appearance but red. On a separate note can some one confirm shock adjustment ie screw in for harder and screw out for softer. Thanks Colin
2019 Plus-4 Royal Guardsman Blue 2020 Subaru 2.5iP 2014 Toyota Landcruiser 200 series 4.5l diesel
