Topics49,899
Posts838,027
Posts: 7 Likes: 1
Posts: 7 Likes: 1 |
I’ve just changed my kingpins and removed the speedo sensor. Put everything back and the suspension is fine but my speedo isn’t working. Is the a set gap the sensor has to be off the back of the hub. Or have I just killed it
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Yes there is a specific gap. I cannot find the thread at present, but DaveW detailed the replacement of the sensor and the gap on a thread in TalkMorgan.
2mm rings a bell but I cannot be sure.
Also, the sensor is quite delicate.
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
Good memory Paul  The gap according to Dave on his Roadster is max 2mm although I think he aimed for 1mm. Dave's full article for axle mounted speed sensor (assuming same for Plus 4) here.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Replacement sensor available from Demon Tweeks : Revotec speed sensor; just under £60 inc VAT.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Good memory Paul  The gap according to Dave on his Roadster is max 2mm although I think he aimed for 1mm. Dave's full article for axle mounted speed sensor (assuming same for Plus 4) minus working pictures here. Scroll down to get the images!
Posts: 327 |
The sensor has a small yellowish light adjacent to the cable entry. With the speedo powered up and road wheel rotated as one of the 5 bolt heads passes the probe the light should illuminate, it's quite dim, you need to look closely. Be sure the 3 wires are connected correctly.
Good memory Paul  The gap according to Dave on his Roadster is max 2mm although I think he aimed for 1mm. Dave's full article for axle mounted speed sensor (assuming same for Plus 4) minus working pictures here. Scroll down to get the images! Thanks Dave - link on my original post ammended accordingly.
