4 members (JMD, JohnHarris, sospan, Hamwich), 317 guests, and 33 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
#769536 18/02/23 03:26 PM
I’ve just changed my kingpins and removed the speedo sensor. Put everything back and the suspension is fine but my speedo isn’t working. Is the a set gap the sensor has to be off the back of the hub. Or have I just killed it
Yes there is a specific gap. I cannot find the thread at present, but DaveW detailed the replacement of the sensor and the gap on a thread in TalkMorgan.
2mm rings a bell but I cannot be sure.
Also, the sensor is quite delicate.
Costock, UK
Disco 5
Good memory Paul thumbs
The gap according to Dave on his Roadster is max 2mm although I think he aimed for 1mm. Dave's full article for axle mounted speed sensor (assuming same for Plus 4) here.
Replacement sensor available from Demon Tweeks : Revotec speed sensor; just under £60 inc VAT.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
The gap according to Dave on his Roadster is max 2mm although I think he aimed for 1mm. Dave's full article for axle mounted speed sensor (assuming same for Plus 4) minus working pictures here.
Scroll down to get the images!
The sensor has a small yellowish light adjacent to the cable entry. With the speedo powered up and road wheel rotated as one of the 5 bolt heads passes the probe the light should illuminate, it's quite dim, you need to look closely. Be sure the 3 wires are connected correctly.
Thanks Dave - link on my original post ammended accordingly.
