7 members (PaulJ, sewin, jbk, uvk33n, JohnHarris, Chris Cosher, TBM),
280
33
Topics49,913
Posts838,166
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Rear wheels off for a good clean and inspection. ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/IMG_3015.md.jpeg) May be a bit late Kevin but good opportunity to pull the brake drums (four screws) then gently peel back slave cylinder rubber covers to check for corrosion. Mine were ok but put a little Ceratec brake grease in there just in case.
Posts: 280 Likes: 58
Posts: 280 Likes: 58 |
Footrest / Storage space ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5069.jpeg) Mrs M isn't one of the largest, she moves her seat far forward for some support for her feet. But that creates conflict with gear change. Elbow against the backrest. That's why I had made a footrest out of hard insulation material. But that always broke. Later, I tried out to use the full car cover as a footrest and save space behind the seats. ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5063.jpeg) That works well. During longer trips the storm cover goes on top to create extra luggage space. ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5065.jpeg) But it's just dangling loose there because the carpet is too short. ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5068.jpeg) I came up with this. ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5072.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5074.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/02/18/DSCN5091.jpeg) Maybe I'll make it lockable so that other (valuable) items can be stored away.
1990 4/4 1.6 Ford CVH Sold 2014 +4 2.0 Ford 2005 BMW Z4 2.2 6Cyl Sold
Posts: 3,829 Likes: 69
Posts: 3,829 Likes: 69 |
I like that, very impressive. Nick
Posts: 27,848 Likes: 766
Posts: 27,848 Likes: 766 |
+1 and the sat nav / phone holder
Posts: 184 Likes: 16
Posts: 184 Likes: 16 |
Love the door stopper Paul.
Sir P
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
Sir P Only just spotted that
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
Having fitted the new handbrake quadrant, but with the old pawl as the new one supplied by MR was incorrect, I checked the gearbox mounts before refitting the cover. I foiund one of the bolts fixing the mounts to the cross member was loose. I was surprised to find that they are self tapping screws rather than threaded bolts. Tempted to replace with rivnuts, but access would be difficult with the gearbox in situ. Guess they are OK as they have been there for 60 years! ![[Linked Image]](https://tm-img.com/images/2023/02/21/GBox-Mount.jpeg)
1956 Plus 4 4 seater
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Grumpy Pa
The should be 1/4 BSF set screws rather than self tappers
Arwyn
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Fitted a new Rotaflex coupling to the prop shaft - what a faff!
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Grumpy Pa
Arwyn My thought also, Seem to have been there some time though. I shall have to find a way to fit rivnuts sometime, but don't want to remove the gearbox.
