4 members (Alastair, Stevecarr, Clipper, JMcL), 377 guests, and 49 robots.
+8Rich 94
Posts837,276
Page 39 of 40 1 2 37 38 39 40
Originally Posted by westgardronning
Roadster S1 V6, 2005. My dash with homemade bezels, made of non-oxidizing aluminium. Morgan Park steering wheel
In my opinion the Roadster S1 had the most attractive standard Morgan dash ever. Very nice.
David
2020 Roadster 3.7 Dove Grey.
I agree David , the only failing is that the trip meter is hard to read.
I have one of these Mig clocks and I’m having difficulty replacing the silver tension ring for the glass. I realise your project was some time ago, but do you have any tips on how to replace the ring.
Managed to fit the ring, so no need for a reply. Thanks all.
The soon to be removed and refinished ribbon grain mahogany dash board of our '64 4/4...
Roadster 2005 V6 3.0L new bezels and replacement 4 bigger buttons.
Before and after
Roadster V6 3.0L 2005
Before and after
That is very neat. I have the same dash, you gave me something to think about. Permit me some questions:
Where did you source these buttons?
Are they a direct swap, regarding size of the hole and also electrical connections?
Do they function the same way, that is lit up when the DRLs are on and getting brighter when switched on?
I take it you have coloured bulbs behind the legends, or just plain?
Is it possible to provide a photo when lit up?
Kind regards,
Robbie
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Before and after
Kind regards,
Robbie
Of course, if the switch lights are just plain yellow or white, there is no need for a photo. Easy to imagine....
Robbie the Norseman
2004 V6 Roadster
Sherwood green
You can change the colour of the buttons on the cheap…
https://www.lemans62.org.uk/uploads/2/5/6/8/25680891/changing_switches_an_alternative_method.pdf
I did this to my dads Roadster, big improvement
I'm sure MK used to have another 3.7 Roadster dash in addition to the two shown here (both of which are the same layout except one is wood and the other leather with an aluminium centre plate). The wood one he is offering now is very nice but the only difference I can see to the standard dash is the centre plate is wood. Unfortunately not much can be done with the standard 3.7 dash. I think I will leave mine as is.
https://www.mk-holztechnik.de/englisch/morgan-accessories/roadster-37-l/index.html
David
