Posts837,993
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Having a bit of mission creep in my winter projects. I removed the bonnet and cowl to have them repaired and repainted and discovered some corrosion on the radiator and decided to pull it out and replace it with an aluminum unit. Once it was out, I noticed the front of the sump was covered with oily grime and, upon further investigation, found it was the front main crankshaft seal that is leaking. I have the parts on the way to replace the seal, but can't find a puller that will fit between the pulley and the suspension crossmember. Can anyone point me to the tool for this?
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
You may not need a puller. Changed mine for a billet one last year and the old one slid off with a bit of gentle persuasion and leverage with a wooden hammer handle.
I soaked it with PB Blaster yesterday and will give it another try today.
