Posts837,931
Posts: 159 |
Hi guys, I am planning an oil change on my 1992 4/4 1.6 xr3i engine Morgan. My question is what oil filter should I be using. I thought it would be a standard Ford filter but when looking for one on the internet the filter that I saw for the cvh was 1985 to 1991 which is a year before my car. Was there a change in 1992 that I am unaware of? Burton Power list the same oil filter for all models:" FORD OIL FILTER X/FLOW OHV KENT, CVH, LOTUS TWIN CAM, BDA, ZETEC SE/SIGMA, ECOBOOST & VALENCIA/HCS EFL500" So presumably nothing changed. Which oil filter have you used? Thanks in advance for what seems a silly question.
Addicted to Morgans. 44 years and still not cured.
1947 series 1 4/4 1992 4/4
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I had a ‘93 cvh efi same as you. I’ll check if I still have the details you need. I did send a copy of the handbook to Gomog to be made available on there. I’ll look at it to see if there is a part number. I think I bought one from Halfords back then but they have changed their stock numbers since then. Just checked gomog....no oil filter part number in there. Here’s a link.... https://www.gomog.com/allmorgan/allmorgan.html
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
Assuming it is a screw on type, why not simply note the details of the existing one? There are then plenty of cross reference tables online to get an alternative manufacturer’s equivalent.
Posts: 37,462 Likes: 988
Posts: 37,462 Likes: 988 |
This look familiar If not get in contact with them as they are good.
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
I use a Mann W712 in my Elan (Kent bottom end) from the local motorfactors. It's quite short but I change it, and the oil, every year, 3 to 5K miles. Cheers John
Posts: 159 |
Thanks guys. I was having a Homer Simpson moment when asking the filter to get. It was a case of being blinded by information from the internet when the solution was as easy as Deejay said. Go in the garage and look what is fitted now! DOH. I did and it was just as John 07 said a Mann W712/43. Purchased from Halfords for under a fiver. Thanks every one who responded.
