4 members (Graham, G4FUJ, Beard, yrr13, nick w), 243 guests, and 53 robots.
+8Rich 79
Luddite 50
Posts837,931
Morganzeal, Pablo
jeepy Offline OP
Hi guys,
I am planning an oil change on my 1992 4/4 1.6 xr3i engine Morgan.
My question is what oil filter should I be using.
I thought it would be a standard Ford filter but when looking for one on the internet the filter that I saw for the cvh was 1985 to 1991 which is a year before my car.
Was there a change in 1992 that I am unaware of?
Burton Power list the same oil filter for all models:" FORD OIL FILTER X/FLOW OHV KENT, CVH, LOTUS TWIN CAM, BDA, ZETEC SE/SIGMA, ECOBOOST & VALENCIA/HCS EFL500"
So presumably nothing changed.
Which oil filter have you used?
Thanks in advance for what seems a silly question.
Addicted to Morgans. 44 years and still not cured.
1947 series 1 4/4
1992 4/4
I had a ‘93 cvh efi same as you. I’ll check if I still have the details you need. I did send a copy of the handbook to Gomog to be made available on there. I’ll look at it to see if there is a part number. I think I bought one from Halfords back then but they have changed their stock numbers since then.
Just checked gomog....no oil filter part number in there.
Here’s a link....
https://www.gomog.com/allmorgan/allmorgan.html
Assuming it is a screw on type, why not simply note the details of the existing one? There are then plenty of cross reference tables online to get an alternative manufacturer’s equivalent.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
This look familiar
If not get in contact with them as they are good.
I use a Mann W712 in my Elan (Kent bottom end) from the local motorfactors. It's quite short but I change it, and the oil, every year, 3 to 5K miles.
Cheers
jeepy Offline OP
Thanks guys.
I was having a Homer Simpson moment when asking the filter to get.
It was a case of being blinded by information from the internet when the solution was as easy as Deejay said.
Go in the garage and look what is fitted now! DOH.
I did and it was just as John 07 said a Mann W712/43.
Purchased from Halfords for under a fiver.
Thanks every one who responded.
1947 series 1 4/4
1992 4/4
