10 members (Pittsartist, Julian BB, DirkM, marshalben, High Hamster, tommog, Alan Patterson, Montegue, Tom Sayles, Guern),
275
106
Topics49,868
Posts837,645
Posts: 375 |
Test and compare the efficiency of the suspension of your MOG with your other cars by using phyphox on your smartphone in order to measure the acceleration. What you fill in a vehicule is the acceleration, with constant speed you don't have any feeling, by example in a lift you fill only the start and the the stop. In order to compare your different cars you must use the same travel and the same speed, vertical acceleration on a bumpy road is linked to the frequency of the oscillations. This is more secure to let a passenger operate the smartphone. You can download the data on your PC and draw the curves with EXCEL or LibreOffice. https://phyphox.org/
Regards 2005 PLUS 4
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
My bum does that for me  I suspect having it documented would leave me dissapointed. Interesting app though.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
 is far more sensitive. I don't need the app or Google im married.
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
+1
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
I found Kidney stones were quite tuned in to stiff suspension
Posts: 375 |
I like your humour but for a scientist your bum acts like a damper, depending on your weight. This is not the best sensor. Use your inner ear, it is directly linked to the brain, and avoid long nerve.
Regards 2005 PLUS 4
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
"and avoid long nerve." is that a euphemism ?
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 396 Likes: 12
Posts: 396 Likes: 12 |
A drive in the 4/4 really helps the running total in Mrs E's step counting app.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
CBY, Thank you for posting this and make us aware of this tool, at one point in time I will look into this. Have you used it and are you able to share results? Thanks,
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 375 |
"and avoid long nerve." is that a euphemism ? No euphemism, only the distance between 2 points.
Regards 2005 PLUS 4
